im looking at a motor that is supposed to be a genuine l34 motor are there any special engine numbers that i should be looking for?
l34 engine numbers
_keaton_
, Oct 12 2006 12:22 PM
5 replies to this topic
#1 _keaton_
Posted 12 October 2006 - 12:22 PM
Posted 12 October 2006 - 12:41 PM
it should have an engine # with a HZ prefix, and a cast date in 1974
#3 _keaton_
Posted 12 October 2006 - 04:05 PM
wat is actually different in the l34 engines?
Posted 12 October 2006 - 06:52 PM
there is a little meat in them in some spots, nothing much different from the later blocks, the heads had larger valves and "roller" rockers, stronger conrods. I am sure there is more but cant remember off the top of my head after a coupla beers.....
#5 _JBM_
Posted 12 October 2006 - 08:40 PM
The engine prefix should be "HZ" as mentioned.
The block itself has some extra webbing that later 308s had added to them.
The heads are the main difference, larger valves and a roller pivot for the rocker arm. The extractors have a joining flange where the pipes are still separated for each cylinder.
The sump is baffled and the conrods are stronger with an "X" on the side.
The oil pump is a high volume one.
The ignition has twin points and twin coils with 4 lobes breaking the contacts instead of 8.
There are other body type mods and the brakes are HQ/J.
James
James
#6 _keaton_
Posted 13 October 2006 - 10:25 AM
any ideas of what a l34 motor would be worth in good condition?
