Guys,
my LSD (banjo) locked up. A few of the guys on here and mechanics I spoke to said it could have had the wrong oil used when I had pinion seal replaced recently. They recommend replacing the oil and driving it to see what happens. So before I put anything in that is supposed to do the job I'd like to know if someone here has replaced their LSD oil and what did they use. This way I'll know for sure its not the dam oil causing me grief. At the moment it has Castrol LSX 85-140 in it.
LSD Oil
_Rob 5000_
, Oct 18 2006 06:41 PM
11 replies to this topic
#1 _Rob 5000_
Posted 18 October 2006 - 06:41 PM
#2 _Eddie_
Posted 18 October 2006 - 08:38 PM
I've used Penrite SAE 85W-140 for my 3.36 Banjo with no sudden explosions or lock ups (as of yet).
#3 _Rob 5000_
Posted 18 October 2006 - 08:48 PM
Eddie is it lsd?
#4 _Eddie_
Posted 18 October 2006 - 08:49 PM
Yep.
#5 _on the limit_
Posted 18 October 2006 - 09:29 PM
the wrong diff oil in limited slip diffs can give you a shuddering noise on corners, but if its clunking, i think you might have another problem!
#6 _Rob 5000_
Posted 19 October 2006 - 07:40 PM
i dropped the centre out and there is no visable damage and there is no metal in the oil. It also seems to be ok when cold but once warmed right up is when the problem starts. The noise on letting the clutch out is like a stuffed uni but once driving there is no noise. However when you slow down and turn a corner thats when the noise starts. So its got to be something with the lsd locking up.
#7 _JBird_
Posted 20 October 2006 - 01:47 AM
I don't have LSD but I use EPX 80W-90. What sorta noise is it? If its a knocking noise when turning corners, your bearings on the axles might be going. If their is a grinding noise the bearings might be completely gone.
#8 _Rob 5000_
Posted 20 October 2006 - 10:18 AM
if it was bearing noise it would be constant and not change even with road surface changes. I'd best describe the noise as clanging and banging.
Posted 20 October 2006 - 10:52 AM
According to the Castrol website the recommended diff oil for an V8 LH/LX is LSX 90 or SAF-XA. The website even mentions that it will prevent clutch chatter which could be the noise you are referring to.
http://www.datateck....ke=25&Model=652
#10 _Rob 5000_
Posted 20 October 2006 - 11:50 AM
thanks Andy, I'll be putting it back in this weekend, I'll post how it goes
#11 _on the limit_
Posted 23 October 2006 - 07:28 PM
if its only doing it when its hot, its either the wrong oil, or what they call "pick-up" on the back of the limited slip gear.
#12 _Rob 5000_
Posted 27 October 2006 - 10:36 PM
thought I'd let you know, I changed the oil and took it round the block 3 times and so far no noise. I'll give it more of a workout over the weekend, am hoping like hell it was only wrong diff oil causing me problem.
