The column in my hatch is buggered it rattles and has heaps of movement in it. I was wondering how to pull the whole thing out in one piece? I have done what i thought needed to be undone to get it out but no go. Anyone know?
Josh
LX Steering column removal
_Woodsy_
, Oct 19 2006 09:17 PM
7 replies to this topic
#1 _TUFF_
Posted 19 October 2006 - 09:17 PM
Posted 19 October 2006 - 11:02 PM
What have you undone so far?
there are a couple of bolts under the dash, some wires and the coupling in the engine bay
#3 _Flamenco_
Posted 20 October 2006 - 01:23 AM
Heaps of movement? Sounds like the collapsible capsules in the bracket may have snapped (only guessing). As tinks said there's the wiring plugs, 3 bolts under the dash also 4 bolts going through the firewall with a rubber surround and the flexible coupling bolts (cotter pins) which you'll need to remove one of...
Posted 20 October 2006 - 12:51 PM
sounds like you might have the same problem i experienced as well as LXCHEV? i had a fracture down the side of the housing which alloud the steering wheel and barrel to be moved around. Very sloppy and dangerous to drive with. LXCHEV i think has a couple picys
#5 _TUFF_
Posted 26 October 2006 - 09:35 PM
I forgot about the 4 bolts holding the panel onto the fire wall i thought it was just a rubber sleeve that went through it. I will be pulling it out on saturday so hopefully no more shakes and rattles.
TUFF
TUFF
Posted 26 October 2006 - 09:40 PM
Hey TUFF, could you get some pics as you go? Could come in handy.
Posted 27 October 2006 - 07:23 AM
And don't bin it...I have a tube out of a UC if you want to rebuild it.
#8 _TUFF_
Posted 28 October 2006 - 02:14 PM
Did'nt get any photos. But i will pull it apart again to get some "when i get some time".... oh the magic saying.
Josh
Josh
