Banjo centre swap
8 replies to this topic
#1 _mal_b_
_mal_b_
Posted 21 October 2006 - 11:42 PM
Just a quick one for you all. With my plans to slap a turbo on my LJ S, I have discovered that my diff ratio is 2.78:1. Take this ratio and assume i still have the 13" rims and the turbo doesn't spool up 'til 3000, it wont get on boost until approx 60 km/h. Now, i have a HZ kingswood sitting around and it has a 3.55:1 centre an I want to do a straight swap. Are the axels the same spline? Are the centres interchangable? Failing those two, can I swap the gears over?
Any responses are very appreciated as I'm in a bit of a pickle with this one
Cheer, Mal
#2 _V8Hatch_
_V8Hatch_
Posted 21 October 2006 - 11:48 PM
I am sure the only difference is the spline apart from that is an easy straight swap.
#3 rodomo
  • 17,999 posts
Posted 22 October 2006 - 12:10 AM
From what I have read, an LJ could have either spline.
#4 _CHOPPER_
_CHOPPER_
Posted 22 October 2006 - 11:50 AM
Most, if not all HZ's had fine spline from the factory. This of course could have been altered over the years. Only 1973 Bathurst XU-1 had fine spline from what I've been told.
#5 _on the limit_
_on the limit_
Posted 23 October 2006 - 07:23 PM
thats correct, all hz were factory fine splines, hx were combo's, corse & fine splines.
#6 _mal_b_
_mal_b_
Posted 23 October 2006 - 09:25 PM
so i would either have to get the axles shortened or the lj axles resplined or swapped for xu-1 items?
cheers, mal
#7 _CHOPPER_
_CHOPPER_
Posted 23 October 2006 - 09:33 PM
Your only two realistic options would be to get a pair of LJ fine spline axles, or swap the spider gears in the HZ centre to coarse spline.
#8 makka
makka
    A m��se once bit my sister
  • 3,559 posts
  • Name:Cohen
Posted 24 October 2006 - 12:33 PM
that makes just 1 realistic option then chopper, fine spline LJ axles are not the easiest thing to find.
where are you located? I have a 3.55 coarse spline centre sitting in my wardrobe.
#9 _mal_b_
_mal_b_
Posted 25 October 2006 - 08:00 PM
i'm in adelaide, so it would probably be cheaper to just swap the spider gears over. if only holden released LJ's with fine spline 3.9:1 gears. life would be so much easier...
