Hey peoples, the radiator has been changed in the old girl at some stage, as the plate which is on the top tank isn't the original shape and now comes off flat kicks up at 45 degrees and then levels out again. It is clearly not original.
I want the engine bay to look nice and original, has anyone else had to replace one of these before ? If so what type of plate is correct for the radiator ?
Thanks Fat Tony.
Lj xu1 radiator plate
_fat tony_
, Oct 25 2006 05:16 AM
5 replies to this topic
_fat tony_
Posted 25 October 2006 - 05:16 AM
Posted 25 October 2006 - 11:02 AM
G'day Fat Tony
Here is an early black and white pic of the LJ engine bay. There are lots of contempory photos showing the same fan guard. Although the guard is similar on all models, I wonder how many XU1s have the correct number of fins per inch on the actual radiator.
Bazza
Bazza
Posted 25 October 2006 - 02:48 PM
original radiater plate is flat and ends in letters HP ..
gtr-xu1 has an original one on his car and knows the numbers ..
Posted 04 November 2006 - 10:29 PM
Anyone know what these numbers are ????
72 lj ????
72 lj ????
_Tangey_
Posted 06 November 2006 - 07:01 AM
Not many original ones around, you can still get the correct core at least.
The plate is flat as stated earlier, the numbers are;
eg. H 73 = 8th month 1973, followed by 2823866 (ring a bell)
First the date, then the part number.
E 72 2823866 for a 6/72 and so on.
Same system as heads, blocks etc.......
_doublin gtr_
Posted 06 November 2006 - 07:28 AM
2823866 xu1 also found in some later lj,s
with manuel gbox and heavy duty radiators
