Can anyone identify this
11 replies to this topic
#1 hatchssv8
hatchssv8
  • 351 posts
Posted 25 October 2006 - 11:14 AM
I got this steering arm with some other bits and for the life of me I cannot identify what model Holden (Torana?) it is used on.
The part number was not found in the LH or LX parts manuals I have.
Can anyone help out with the identification and/or usage of this part. the nuber looks like 5053
These below are LH/X and UC as a comparison
Cheers, Max
Edited by enderwigginau, 26 October 2006 - 01:01 PM.
#2 makka
makka
    A m��se once bit my sister
  • 3,559 posts
  • Name:Cohen
Posted 25 October 2006 - 12:56 PM
LC/J maybe?
or some other Holden like a Kingswood
#3 _big chris_
_big chris_
Posted 25 October 2006 - 01:13 PM
Hi,
If it is a Holden part,
at a guess from HK T G Series,
as it looks like has the tie rod mounted to the rear of the axle,
Would suggest a non rack and pinion model. maybe?
Chris
#4 hatchssv8
hatchssv8
  • 351 posts
Posted 25 October 2006 - 01:22 PM
Tend to somewhat agree with you Chris. the funny thing is that the stub axles I took them off from are used on Torana. I thought that the Torana LH/X stubs were unique from all other Holdens (the KPI factor). Can anyone confirm this.
#5 makka
makka
  • 3,559 posts
  • Name:Cohen
Posted 25 October 2006 - 02:42 PM
LH/X stubs are the same as LC/J AFAIK, HQ have a different inclination (HQ 9deg, LH 7 deg, I think), and are the same as HR ect, but have a 1 inch drop
#6 _DocDamage_
_DocDamage_
Posted 25 October 2006 - 04:14 PM
lc/lj stubs do seem to be different to lh/lx. I pulled a dodgey to get through rego with a set of lx disc stubs. I might have got something wrong but I couldn't get the steering to work in a way I'd be happy with in the long term.
#7 hatchssv8
hatchssv8
  • 351 posts
Posted 25 October 2006 - 04:20 PM
Can anyone list the part numbers for LC/J stubs, both disc and drum brake.
The LH/X part numbers are
LH) 9934548 RH) 9934547
LH) 9942927 RH) 9942926
Edited by hatchssv8, 25 October 2006 - 04:28 PM.
#8 makka
makka
  • 3,559 posts
  • Name:Cohen
Posted 25 October 2006 - 04:44 PM
they may be different stubs, but I am pretty sure that they share the same KPI and ride height
#9 _DocDamage_
_DocDamage_
Posted 25 October 2006 - 05:41 PM
yes and yes but I couldn't find a steering arm to work with them.
#10 Toranamat69
Toranamat69
    Forum R&D Officer
  • 2,117 posts
Posted 25 October 2006 - 05:52 PM
I don't have a set here to check but those steering arms at the top look like LC/LJ to me.
As far as I know the LC and LX stubs are interchangable (assuming disc or drum). But again I don't have any LC stuff here now to compare.
The Toranas have the 9 degree KPI and the big holdens have the 7 degrees.
M@
#11 makka
makka
  • 3,559 posts
  • Name:Cohen
Posted 26 October 2006 - 12:22 PM
M@
I knew it was that or vice versa
#12 _rorym_
Posted 05 November 2006 - 11:56 AM
Looks like the drum brake LJ arm I just pulled of..numbers are hard to read but it could be 505?..
