Clutch testing
Posted 30 October 2006 - 05:25 PM
help any one?
#2 _LH SL/R 5000_
Posted 30 October 2006 - 06:25 PM
Did you bed the clutch in, ie drive normally for say 500km before giving it stick?
Was the flywheel face in good condition (ie did'nt require a grind)?
Is the clutch fully releasing?
Posted 30 October 2006 - 08:18 PM
Posted 31 October 2006 - 12:07 AM
Posted 31 October 2006 - 01:07 AM
i just want to make sure im not destroying the fresh clutch... but i dont think there is anything i can do to help it... the cable has slack in it so the clutch must be under full clamp load....
Edited by laspy, 31 October 2006 - 01:08 AM.
Posted 31 October 2006 - 01:24 AM
or have it dynoed, should tell you most problems....
Posted 31 October 2006 - 01:29 AM
cheers ALX76 you save the day at all hours of the morning
Posted 31 October 2006 - 01:35 AM
i mainly had the problem at first on the express way in third when opening the secondaries, and then at almost every corner first thru second and into third as i ran the motor in.
dont ever doubt the ol 253.
Posted 31 October 2006 - 01:47 AM
Posted 31 October 2006 - 01:53 AM
with slipping (either tyres or clutch) the revs go up (3000 to 6000rpm no probs in my case)
anyway you should have your car in optimum tune at all times, call it prevenative maintanence. (where is the spell checker)
Edited by ALX76, 31 October 2006 - 01:55 AM.
#11 _LH SL/R 5000_
Posted 31 October 2006 - 08:04 AM
#12 _devilsadvocate_
Posted 31 October 2006 - 10:06 AM
The "old" way to test clutches was to put the front wheels hard up against a curb, put the car in second gear and try drive over it, if it stalled the clutch was good....
Perhaps when you are on the road again, find the steepest hill that you can and attach a heavy trailer and/or partially engage the handbrake, then give it full throttle in one of the higher gears while doing at least 2000rpm, if it doesnt appear to slip in these conditions.........should be good. This will be more effective in loading up the clutch and not have you going too fast either.
Posted 31 October 2006 - 12:14 PM
