Does it fit?
#1 _LX streeter_
Posted 31 October 2006 - 09:27 PM
I'm about to start a conversion by pulling out my 6 in my LX. I am going to stick
a SB 383 in and a TH400. The problem I have is I don't know if the TH400 will
fit in without having to modify or even cut out the tunnel and fabricate a new one.
I understand that I will have to make a trans cross member coz they are about 2"
lower than a Traumatic( Is this true? ). I dont want to use a TH350 coz it might not handle the hp.
Any help will be great thanx.
#2 _v8slrtorana_
Posted 31 October 2006 - 09:40 PM
#3 _HatchmanSS76_
Posted 01 November 2006 - 08:19 PM
Posted 01 November 2006 - 09:00 PM
Thats what I'm using with my 383 anyway
#5 _UCV80_
Posted 02 November 2006 - 07:58 PM
I might give it a go in the next few weeks
#6 _HatchmanSS76_
Posted 03 November 2006 - 11:08 PM
Sorry I can't remember where and on whos car I saw it. It may have been out at the drags not long after I put the new Turbo 350 in mine as I clearly remember it as being some thing I didn't know could be done.can anyone else confirm the "turning the crossmemer upside down" theory.
Posted 04 November 2006 - 01:21 PM
That would be great if you wanted the gearbox to drag along the ground behind you.....can anyone else confirm the "turning the crossmemer upside down" theory.
It could however be possible to get it to work if you fitted it back to front.
#8 _v8slrtorana_
Posted 11 November 2006 - 10:31 PM
The turbo 400 needs to sit lower to clear the transmission tunnel.That would be great if you wanted the gearbox to drag along the ground behind you.....
Problems that can occur are the hand brake cable rubs on the tailshaft.
The motor leans back, reqiring a small starter motor to clean the chassis.
Fitting a holden x member back to front, wont do anything.
#9 _Roadknight_
Posted 15 November 2006 - 10:38 AM
As for a th400 can't help sorry.
I installed a 350 with th350 box and did not require any new parts or body mods.
