lc / lj brake upgrades
#1 _holdon_
Posted 06 November 2006 - 08:18 AM
ive done a quick search and cant find any info on hq brakes to lc.
whats needed for the conversion. i was told just the hq brakes and lc drum stubs axels. is that all?
is ther any grinding/modifying needed?
does anyone have a 'how to' guide?
#2 _LHoon_
Posted 06 November 2006 - 08:31 AM
You will need:
HQ stub axles with shorter (Harrop/A9X) steering arms
HQ rotors
HQ calipers, pads, brake lines
Yes a small amount of grinding is required on the top control arm. This is because the caliper hits it at full lock under load.
Keep searching the forums, you will find more info on this conversion. I had thousands of photos which I can no longer find. I send some to Dattoman about 18 months ago for him to include on his 'how to' website... but I don't think he got around to doing that.
#3 _holdon_
Posted 06 November 2006 - 08:39 AM
so if i search for lx/lh to hq threads i should be right?
how much approx will it cost. (2nd hand to new)
so you dont/cant use lc drum stubs.....
was it a difficult conversion? is it highly recomended?
what other bigger/better brake upgrades are there for lc/lj toranas?
Edited by holdon, 06 November 2006 - 08:49 AM.
#4 _CHOPPER_
Posted 06 November 2006 - 07:13 PM
Posted 06 November 2006 - 07:26 PM
RIM
#6 _CHOPPER_
Posted 06 November 2006 - 07:49 PM
Forgot to mention that's for HQ front brakes onto an LX. Different steering arms may be required for HQ brakes onto an LC/LJ.Including the Harrop arms, allow about $650.
Posted 06 November 2006 - 09:59 PM
Unless you contact Castlemain Rod Shop and see if they have bolt on brackets to suit those stubs
#8 _CHOPPER_
Posted 07 November 2006 - 09:59 AM
#9 _holdon_
Posted 08 November 2006 - 08:18 AM
so it seams im looking at $300 for the adapters/maching. then just the brakes (disks, calipers, pads ect)
it seams more reasonally priced compared to the hopper stoppers conversion ($1200) - are they just HQ brakes aswell?
what are the volvo brakes like - just as much work required?
thanks
#10 _JBird_
Posted 08 November 2006 - 11:10 AM
The HQ upgrade is good for the budget conscious and if your not really going to track your car etc.
As is the volvo conversion. Both would be better than the stock LC/LJ brakes.
There's plenty of threads on this. Try narrowing your search down by just typing in "Volvo" or "HQ brakes" Or use the advance search function.
#11 _CHOPPER_
Posted 08 November 2006 - 03:38 PM
Your intended conversion:
CRS kit $300
New discs $160
New calipers $200
New bearings $40
New brake hoses $100
Drum brake stubs $150
Plus a few piddly bits
We are then looking at $1050 compared to $1200. I would spend the extra.
Edited by CHOPPER, 08 November 2006 - 03:39 PM.
#12 _JBird_
Posted 08 November 2006 - 06:07 PM
The hoppers kit seems cheap in comparison unless you have all the parts just lying around I would spend the extra. I guess it also comes down to wheel choice, you might need new wheels after installing the hoppers kit as most people go for commodore stud pattern.
#13 _CHOPPER_
Posted 08 November 2006 - 07:20 PM
