You crack me up!!
Cheers Greg..
Posted 02 January 2006 - 07:50 PM
Posted 02 January 2006 - 08:03 PM
Snort some crack first too Chopp... That'll make it seem better, or faster or louder whichever one blows your hair back...Thanks for the suggestion about using speaker wire for spark plug leads. I might try that one day after several beers.
Posted 02 January 2006 - 08:44 PM
Posted 02 January 2006 - 08:56 PM
Posted 02 January 2006 - 10:25 PM
Posted 02 January 2006 - 10:44 PM
Id say thats some quite objective testing there Tiny(although we need to know were you leaning on a fender, footwear etc) Not that it would make any difference to whether you got a shock or not, why were you holding all the leads at once? Glad they do put more insulation on those leads.Ive managed to grab all my spark plug wires ( those magnecors) while running on my MSD 6A system... Ive only ever gotten a shock (Twice damnit!) from the coil lead which is not a magnecor!
Anyway.. thats my subjective testing..
Posted 03 January 2006 - 08:58 AM
Posted 03 January 2006 - 09:31 AM
Posted 03 January 2006 - 09:50 PM
Posted 03 January 2006 - 10:24 PM
If you are shielding wires with rubber check on the carbon content first as some rubber like epdm can be conductive.
Posted 04 January 2006 - 01:37 AM
No drama's Tiny, they are possible to change (the boots that is). It's also possible to get what the manufacturer's call 'High Temp' boots, which are a reddish colour. We use them for tight engine bays, LPG and turbo applications.BOTTLEDUP: Ive got a magnecor lead that ive burnt the boot on ( 90degree boot at the spark plug end), and i wonder if it would be possible to change the boot easily? Would i need to cut off the connector to get the boot on/off? It doesnt seem to want to come off as it is! Or... i may just buy a set from you... ( though i might specify some lengths as a couple of mine are tight! and my coil lead is long due to being hidden in the dash ( dont ask!) )
Posted 04 January 2006 - 10:44 AM
Thanks for that dave, My magnecors are the 8Mm red leads wit red boots.. i dont know if these are the high temp ones you speak of or if they were just made to suit the lead colour.. but touching the pipe certainly burnt it!,Jan 4 2006, 02:37 AM] No drama's Tiny, they are possible to change (the boots that is). It's also possible to get what the manufacturer's call 'High Temp' boots, which are a reddish colour. We use them for tight engine bays, LPG and turbo applications.
Posted 05 January 2006 - 01:23 PM
Posted 05 January 2006 - 04:18 PM
Posted 06 January 2006 - 10:33 AM
Posted 06 January 2006 - 11:41 AM
Posted 08 January 2006 - 10:39 PM
