hi i just got a trans rebuilt and the told me to flush out the trans line holes with kero is this normal
tranz flush
_bronjak_
, Nov 10 2006 12:13 AM
8 replies to this topic
#1 _bronjak_
Posted 10 November 2006 - 12:13 AM
#2 _Oldn64_
Posted 10 November 2006 - 10:01 AM
Yes.
After time the oil will become burnt if not maintained correctly. (Hence the brown colour not red) AT this point if that does happen changing the fluid will nto fix the issue as teh old stuff trapped in the system will containmate the new oil. So a flush of kero is done to clean teh system then air is blown through. once this has happened the new oil will stay red. I usually blow compressed air through the setup after the kero to get as much kero out as possible. May I suggest that the pressure be too high you do not need much. Remember the radiator hold a tank in it for cooling and this does hold a quantity of fluid, Same thing goes for a dedicated trans cooler.
#3 _bronjak_
Posted 10 November 2006 - 06:15 PM
just another question does kero evaporate quickly
#4 _Oldn64_
Posted 10 November 2006 - 08:15 PM
no. (simple response)
#5 _bronjak_
Posted 10 November 2006 - 08:52 PM
cheers mate
#6 _Oldn64_
Posted 10 November 2006 - 09:01 PM
Extended response. This is why I suggested the air to blow it through. Most auto mech use the kero then run fuild straight through it into a catchment bin. and just use the new fluid as a detergent/washign agent. In your environment you will not have that option.
#7 _CHOPPER_
Posted 10 November 2006 - 09:18 PM
Not that I've tried it, but could you use some metho after the kero to try and get rid of the kero?
#8 _bronjak_
Posted 11 November 2006 - 04:43 PM
so kero is safe in transmission cause when i got it bak from the shop it stank of kero so im wondering if theres a little in the trans would that damage anything
#9 _Oldn64_
Posted 13 November 2006 - 07:26 PM
You will find it is shellite not kero (similar smell) they use this as a solvent to clean the parts.
