Hi,
I recently bought a disc brake LSD 9" for my ss hatch, i have been told it is either 3.55 or 3.7:1 centre, i have taken the centre out and the only numbers i could find were as follows, these were stamped on the crown wheel:
FORD D 1 AW 4210 A 3
does anyone know what these numbers mean and how i could find out what ratio it is?
any help is appreciated
9" queries
_heppy_ss_76_
, Nov 12 2006 09:46 AM
4 replies to this topic
#1 _heppy_ss_76_
Posted 12 November 2006 - 09:46 AM
Posted 12 November 2006 - 09:56 AM
That is a Ford part No. There should also be another number ie 33/11 this is the ratio (33/11 =3.00) if not then count the number of teeth on the crown wheel and divide by the number of teeth on the pinion gear.
#3 _DocDamage_
Posted 12 November 2006 - 09:57 AM
Someone may be able to help with those numbers, but if you have it out count the teeth.
Edit: too slow.
Edit: too slow.
Edited by DocDamage, 12 November 2006 - 09:58 AM.
#4 _heppy_ss_76_
Posted 12 November 2006 - 12:36 PM
ok i counted it up its 44/16 = 2.75, does this sound common??
how much could i expect to get for a 2.75 LSD 28 spline centre if i were to sell it and how much would it cost to get a 3.5 LSD centre?
Posted 12 November 2006 - 01:42 PM
Id give u $200 for the centre, just for the case and the LSD, the gears aren't worth 2 bob, cost more to change gears then its worth.
3.55 centre around $800-1000 for one with new gears.
