My Diff Is Leaking! Time to Fix It
Posted 13 November 2006 - 05:03 PM
I know i need oil but what type of oil and how much of it....im pretty sure its all stock diff....
do i buy diff gasket?
it would be a good chance for me to see what my gears are too.....
#2 _IPRALC4Door_
Posted 13 November 2006 - 05:25 PM
As for Oil, Most heavy gear oils will do. I use Redline Red shockproof in the race car, and have no issues at all. It's not cheap, though. Most BP oils are good stuff, I've found, too. Just fill to the level where the oil starts to leak out the fill hole and that should be all you need.
#3 _Rob 5000_
Posted 13 November 2006 - 05:43 PM
Posted 13 November 2006 - 05:44 PM
#5 _Rob 5000_
Posted 13 November 2006 - 06:04 PM
#6 _draglc_
Posted 13 November 2006 - 08:46 PM
A1
#7 _Rob 5000_
Posted 13 November 2006 - 09:03 PM
#8 _JBird_
Posted 13 November 2006 - 10:30 PM
So true. The gasket sometimes doesn't let it seal proper around the bolts cause they're not cut exactly perfect. Also put some "blue max" on the bottom threads of the bolts when putting it back in. And be sure to wait till the sealant is 'tacky' (should be a couple of minutes twiddling your thumbs) before sticking the two halves together!more chance of leaking with a gasket than without it. That blue max is the go. Even the big diffs in trucks just use blue max and no gasket.
Good luck!
Posted 15 November 2006 - 10:09 AM
Cheers for the tips
btw how long should I let it dry till i can drive it again....just 20mins? 1hour?
Edited by gooley, 15 November 2006 - 10:12 AM.
#10 _IPRALC4Door_
Posted 15 November 2006 - 07:56 PM
If you want to be super safe, give it a few minutes to allow the sealant to take. The tube will tell you how long.
But as a guide, we once did a hot swap of a blown diff in a Mazda RX4 race car between races, approx 2-3 hours, and the oil from that diff change hasn't even looked like leaking since then. That's about 3 months.
Edited by IPRALC4Door, 15 November 2006 - 07:57 PM.
