which gears to go for???
#1 _Chamois hatch_
Posted 15 November 2006 - 12:11 AM
the drivline is EFI v8 + supra 5 speed + 9 inch.
i was going to go with either 3.5 or 3.7, but i want to hear some of your experiences with these ratios. reading from the other threads 3.5's are the go......
also how will this gear change alter my speedo, also, where in syndey can i get it done, any mobs i should watch out for. Craft diff springs to mind....most importantly how much can i expect to pay?
any advise greatly appreciated.....
john
Posted 15 November 2006 - 09:44 AM
Ive got a "gear calculator" program that will help you decide..
I'll post a link to it shortly to help you make up your mind!
I'd go with either CRAFT or Maybe Bosnjak engineering..
The guy who set up my 3.25 LSD centre has retired...
Expect to pay around $500 for a ratio swap i believe maybe more!
#4 _Chamois hatch_
Posted 15 November 2006 - 09:49 AM
john
Posted 15 November 2006 - 12:37 PM
Terry is at wetherill park......where are bosnjak located at?
both Craft and Bosnjak do good work but Bosnjak may be a lil more exp. have used both and happy with both.
id go to Bosnjak if the job will include welding. he does top work and probably hundreds of toranas.
Edited by ALX76, 15 November 2006 - 12:42 PM.
#6 _Chamois hatch_
Posted 15 November 2006 - 04:28 PM
#7 _timbotorrie_
Posted 15 November 2006 - 05:35 PM
i would maybe put 3.5s in but 1st may be a waste of time, and may result in gearbox breakages as 1st to 2nd needs to be changed easy for a supra to survive, and dont load up 5th gear either, drop it back to fourth before accelrating
Posted 15 November 2006 - 09:10 PM
#9 _Chamois hatch_
Posted 15 November 2006 - 09:28 PM
what are the gear ratio's of celica boxes. are all celica boxes the same?
#10 _bango_
Posted 18 November 2006 - 12:50 PM
#11 _luv the uc_
Posted 19 November 2006 - 09:44 AM
Hey John, the speedo in your car is reprogramable, Have a look thru the papers and there should be the instructions on how to do this. Cheers, Stevehi guys well its time to replace the 2.75 ratio with something a bit more sensible.....
john
#12 _Chamois hatch_
Posted 19 November 2006 - 11:45 AM
