Well as the topic suggeste, I am wondering if the WB !" mastercylinder will fit LH/LX.
I've got some WB Stato disc rotors, calipers and stubs for sale and would like to know if the cylinder can be used with them on a Torry.
if anyone is interested, I'll put them in the for sale section once I know about the cylinder.
WB 1" Master Cylinder - will it fit Torana ?
micklx
, Nov 19 2006 09:58 PM
5 replies to this topic
Posted 19 November 2006 - 09:58 PM
Posted 20 November 2006 - 12:31 AM
It won't bolt straight onto a Torana booster unless its a late UC one that already has a 15/16 style master
If you modify the booster front cannister to take diagonal mount and shorten the pushrod then yes it could be used
Posted 20 November 2006 - 06:15 AM
And remember the back fitting is one size larger one WB ones.
#4 _CHOPPER_
Posted 20 November 2006 - 04:28 PM
Mick, I'll probably be needing the WB M/C for my WB. I could also use it for my street UC, as the booster has the offset bolt pattern. Is it a disc/disc or a disc/drum unit and how much?
#5 _bango_
Posted 21 November 2006 - 04:51 PM
Did the A9x booster had the offset/diaganal mounting of master cylinder?There was one on ebay a few weeks ago i think..
Posted 21 November 2006 - 09:23 PM
Yes
