new battery
#1 _LX8VD69_
Posted 20 November 2006 - 06:50 AM
cheers adam
#2 _Flamenco_
Posted 20 November 2006 - 11:08 AM
#3 _LX8VD69_
Posted 20 November 2006 - 11:26 AM
#4 _CHOPPER_
Posted 20 November 2006 - 04:42 PM
#5 _LX8VD69_
Posted 20 November 2006 - 04:46 PM
cheers adam
#6 _CHOPPER_
Posted 20 November 2006 - 05:14 PM
Posted 20 November 2006 - 06:45 PM
The AGM deep cycle batteries can be used for starting and will not leak. I use them in my boat ( 2 x 100ah and 1 x 200ah ) to start twin SBC and run the house electrics.
http://www.absorbedp...roducts/12volt/
For my spare car I bought an automatic battery charger from REPCO for around $40 that monitors the battery voltage and tops up when required. I have mine wired to the battery using the supplied cable and the connector pokes out thru the grill. If you look at the picture you will see it comes with battery clips and a cable with eyes to bolt to the battery.
http://www.projecta....d/3/asset_id/15
Edited by AndyCullen, 20 November 2006 - 06:59 PM.
#8 _devilsadvocate_
Posted 20 November 2006 - 08:38 PM
The exide listing for marine batteries lists some healthy cca ratings?
Is perhaps the misunderstanding here is that "marine battery" doesnt necessarily mean deep cycle battery?
Edited by devilsadvocate, 20 November 2006 - 08:46 PM.
#9 _CHOPPER_
Posted 20 November 2006 - 09:29 PM
Most battery manufactures do not recommend using deep cycle batteries for starting as they are designed to provide low current over an extended period versus a staring battery that provides high current over a short period.
They are designed to start engines, but if the engine requires a high CCA rating to start it, then a high capacity battery ( eg: N70ZZ for a 4x4 application ) would be more suitable. Unless of course the engine is left stationary for extended periods ( eg: house boat motor that only gets used a couple of times a year ), then the deep cycle battery is the correct battery.
#1 Andy, little puzzled with above, arent marine batteries used to start marine engines as well.......needing the same start current or larger as car engines?
#2 The exide listing for marine batteries lists some healthy cca ratings?
#3 Is perhaps the misunderstanding here is that "marine battery" doesnt necessarily mean deep cycle battery?
#1 Already answered.
#2 Not unusual to have 15+ litre diesel boat motors.
#3 Correct. There are marine batteries that aren't deep cycle batteries.
Hope this clears things up a bit, instead of stirring up more mud.
Posted 20 November 2006 - 10:05 PM
I think the reason that wet deep cycle batteries are not recommended to be used as starting batteries is that the number of starting cycles significantly reduces the life of the wet deep cycle battery and they do not deliver as high CCA for the size when compared with a staring battery.
The 100 Ah deep cycle AGM batteries on my boat are rated at 850 CCA so they have no problems supplying starting current but they are rather large 330 x 172 x 215. The AGM battery design typically delivers higher current than wet batteries.
Personally I would not fit a wet battery in anything I own. Sooner or later the chances are they will end up leaking and eating your car. On a boat if salt water comes into contact with battery acid it produces lethal chlorine gas.
I currently have an optima battery and the charger I mentioned in my Torana. The absorbed power AGM GT12-40C battery looks like a much cheaper replacement but I was not aware of them at the time. However without the battery charger it will not take long for a car alarm to flatten a 40 Ah deep cycle battery. Allowing the battery to fall below 11 volts severely shortens its life.
Posted 20 November 2006 - 10:10 PM
#12 _CHOPPER_
Posted 20 November 2006 - 10:22 PM
Marine and 4WD batteries are designed to take a beating that the average car battery is not exposed to (waves, sand dunes).
Are you talking about excessive vibration?
Posted 20 November 2006 - 10:38 PM
Quote from the Exide Marine.
http://www.exide.com...ucts/marine.php?
Built rugged to resist impact and rough water vibration - a leading cause of failure in marine batteries. No-Vibe� anchor bonded plates in polyethylene envelopes provide superior vibration resistance for an extra long life.
Quote from Exide 4WD
http://www.exide.com...roducts/4wd.php?
It's durable case design resists impact and off-road vibration - the leading cause of failure in batteries
#14 _Oldn64_
Posted 21 November 2006 - 07:18 AM
I would purchase a normal (high current) automotive battery and a solar charging cell (from reject shop or something.) While I do not have teh wiring diagram here I think the cig lighter is constant 12V if not then you could place another under dash somewhere that will work for this. this will keep the battery topped up and the car will start first time every time. I do this on a number of my cars which are at the farm so that when I wish to start them it is not a weekend ordeal. Just a thought from left field...
Posted 21 November 2006 - 07:30 AM
#16 _DocDamage_
Posted 21 November 2006 - 07:39 AM
If you park the car in a garage, then get a regulated battery charger with a maintainence cycle, I think mine cost around $60, then you have both a good battery and a charger if you need it.
#17 _devilsadvocate_
Posted 21 November 2006 - 08:39 AM
might have misread a number and not taken in a k ^what a shame, cant you guys organise a cruise for him so he can get out and enjoy his car, 15 klms in 5 years??? I'd go nuts if i couldn't drive mine at least once a fortnight.
Edited by devilsadvocate, 21 November 2006 - 08:51 AM.
Posted 21 November 2006 - 12:18 PM
If you use a solar panel then make sure it has a regulator to prevent overcharging. Most panel's are sold without regulator's.I would purchase a normal (high current) automotive battery and a solar charging cell (from reject shop or something.)
