anyone know the what the length of a trimatic and short snout turbo 350 are? also do they have the same spline count on the input shaft connecting to the tailshaft?
Trimatic vs Turbo 350
_355lxss_
, Nov 22 2006 08:48 AM
7 replies to this topic
#1 _355lxss_
Posted 22 November 2006 - 08:48 AM
#2 _UCV80_
Posted 22 November 2006 - 11:11 AM
iv heard with the short snout turbo box, you dont need to shorten the torana tailshaft.
which means they would be very close in lenth to a trimatic.
i have a long nose tubo box and its soooo long!
Splines are identical
Posted 22 November 2006 - 12:53 PM
When I changed from a 253 trimatic to 308 TH350 I do not recall having to alter the tailshaft. I still have the tailshaft in the shed so I can measure it if you want.
Posted 22 November 2006 - 01:25 PM
is it even the same crossmember?
Posted 22 November 2006 - 01:55 PM
Hi Guys.
The tailshaft is the same length & splines. The x-member is different, the mount is further forward & lower down. The mount position os a TH350 is the same as V8 Powerglide & Saginaw.
Dr Terry.
Dr Terry.
Posted 22 November 2006 - 01:57 PM
I used a Castlemain Rod Shop crossmember and speedo cable.
I tried to use the standard cable shifter from a WB statesman but I had clearance problems at the gearbox. The standard rod shifter from a HZ ( I think ) fitted perfectly. I still have the shifter if you are looking for one.
Posted 22 November 2006 - 02:43 PM
cheers for that.... i was just wondering.... future plans one day...
#8 _355lxss_
Posted 22 November 2006 - 02:51 PM
cool so i can go ahead and order the tailshaft to suit the 9in to trimatic, and then when it comes time to change engine/trans (turbo 350) it should still bolt up without any problems.
