Replacing Bushes in Front End
#1 _pallbag_
Posted 23 November 2006 - 07:06 PM
Was wondering if the following pics of a worn "hole" on the body for the mounting of the top bushes is anything too be concerned about. My mechanic says there shouldnt be so much of a wear mark in the hole where the bushes go thru the chassis? He is going to weld it back to "round" but says something has caused it and I ask your advice to what may have ??
The rubbers themselves ...
A better picture of where the holes are in case my description sucks ...
Also, he says that in the following picture the 2 holes may or may not be standard and if they mean anything to anyone here ?
And is there a chance that the alignment of the sub-frame is out causing the holes to wear unevenly ?
More pics available HERE.
All thoughts/theories accepted and appreciated greatly in advance.
Posted 23 November 2006 - 09:12 PM
The rubber bush looks a bit strange like maybe the step had not been located properly in the chassis rail properly before tightening or maybe it wasn't tightened properly.
I reckon you should leave the upper control arm bolts in the bottom holes where they are now. There is another thread about this somewhere.
M@
#3 _JBird_
Posted 23 November 2006 - 10:43 PM
Posted 24 November 2006 - 12:47 AM
Edited by gtrboyy, 24 November 2006 - 12:49 AM.
#5 _JBird_
Posted 24 November 2006 - 12:58 AM
#6 _pallbag_
Posted 24 November 2006 - 05:44 AM
#7 _rorym_
Posted 24 November 2006 - 07:20 AM
Posted 24 November 2006 - 08:42 AM
check that when you install the member is it central to the locating holes.
maybe the bushes were loose over time and fixing the wear and new bushes should fix the problem.
Posted 24 November 2006 - 04:11 PM
If the bushes all looked okay, maybe they were changed previously and someone convieniently ignored the oval shaped holes - just food for thought if you cannot find the problem.
Can you see a wear spot on the crush tubes where it has been rubbing on the chassis rails?
M@
#10 _pallbag_
Posted 29 November 2006 - 05:56 PM
My mechaninc thinks car may have had a hit at some stage adding to the poor alignment of the bushes and some of the other adjustments/bolts not seeming to be truely aligned up with holes ... blah blah blah. One small problems seems to keep leading to another !!!
Should the two rubbers that go into subframe on each side be exact distance apart? My back rubbers are about 15-20 mm wider from centre of rubber to centre of runner compared to the two at the front of the subframe.
Urgent responses appreciated.
Posted 30 November 2006 - 03:10 PM
http://www.gmh-toran...?showtopic=2065
From the other thread it appears 794F and 792R centre to centre was the result for three k-frames and one 790F and 789R.
I measured my power steering front end which is LX RTS and it was 789F and 787R which made me think it had sagged from the V8 and power steering mods. I then measured the spare UC front which had a six and and came up with the same measurements. So I guess it must be within typical tolerance's.
