i found a Celica 5 Spd gearbox with housing, clutch, tailshaft and Hydraulic setup....come from a HT Premier....
Now my question is can i just take out the gearbox and get the tailshaft shortened (Cut and Balanced) and place it in my Torana....will it all fit easy....????
The wreckers salesman says Hydraulic is better than mechanical.....
do i need Gearbox Crossmembers or will it fit wioth the HT Gearbox crossmember?
Celica 5 Spd in LC from HT Prem
gooley
, Nov 25 2006 12:41 PM
8 replies to this topic
Posted 25 November 2006 - 12:41 PM
#2 _HB1200_
Posted 25 November 2006 - 01:04 PM
You will need to modify your gearbox crossmember or buy on allready done. You will also need the spigot bush and a speedo cable to suit your car. It should fit easy, plenty of people have done it before.
HB1200
HB1200
#3 _Chamois hatch_
Posted 25 November 2006 - 01:33 PM
bit of topic but does anyone have the gearbos ratio's for celica 5 speeds?
sorry bout the thread steal.....
#4 _Oldn64_
Posted 25 November 2006 - 02:13 PM
I did have a link to a website with all of these information pieces, but that was two pc's ago, let me go through my back ups..bit of topic but does anyone have the gearbos ratio's for celica 5 speeds?
#5 _Chamois hatch_
Posted 25 November 2006 - 02:16 PM
that would be geat Oldn.
#6 _73LJWhiteSL_
Posted 26 November 2006 - 05:42 PM
This thread has a list of what you will need for the conversion.
http://www.gmh-toran...showtopic=10869
You could just get the tailshaft shortened, but you may want to check the HT rear uni joint attaches to the diff the same way as the LC/J one does. If not swap the yoke over and get you LC/J Torana tailshaft shortened. Thats why did.
Personaly i would go with a cable clutch, but provided the hydrolic clutch isn't stuffed use that.
I am not sure but i think the HT crossmember will be different to the LC/J one. You can get one from CRS.
Steve
Steve
#7 _MRNOS_
Posted 27 November 2006 - 07:41 AM
Ask draglc he had 1 in his LC, just sold it
#8 _smelvin_
#9 _Oldn64_
Posted 01 December 2006 - 08:19 PM
That is the one but it has been upgraded lately...
