Just wondering if anyone knows much about ford stud pattern. Been looking at some rims on ebay and some are advertised as suit pre-au, so just quickly anyone know if ford has different stud patterns? At moment im just looking for some cheap and nasty 15" rims so once i am at a stage where car can off stands it'll be movable.
(Will be going to ford stud for rear disc setup if anyones wondering about question.)
Cheers,
Baz.
Ford stud pattern
_Chaotic_
, Nov 26 2006 01:15 AM
7 replies to this topic
#1 _Chaotic_
Posted 26 November 2006 - 01:15 AM
#2 _ChiaLX_
Posted 26 November 2006 - 06:54 AM
CHOPPER would be the man to ask as he is very knowledgable in this area.
I think they are the same pattern throut the models (very early or 4 cyl) may be different .
I think you will find that offsets differ mainly between models.
#3 _Oldn64_
Posted 26 November 2006 - 06:58 AM
The pattern does not change but teh offset does this is the preAU bit. From memory they have a near zero offset where as the post au are around the 30P offset.
Posted 26 November 2006 - 08:12 AM
Stud pattern is different to all Holden 5 stud, will fit Valiant.
#5 _Oldn64_
Posted 26 November 2006 - 08:13 AM
Will fit late Valiant not early, also Leyland P76 but anyways..Stud pattern is different to all Holden 5 stud, will fit Valiant.
Ford 5 x 114.3mm
Early holden 5 x 108mm
HQ 5 x 120.6mm
Commodore 5 x 120.0mm
Early ford 4 x 114.3mm
early early holden 5 x 210mm (I think ie FX/J, memory hazzy on that one)
Posted 26 November 2006 - 09:54 AM
even some toyotas and mitsubishis have same pattern, I have some old ford hotwires on the hilux work ute
#7 _Chaotic_
Posted 26 November 2006 - 10:01 AM
I know that nissan, ford and toyota are same.
#8 _Leakey_
Posted 26 November 2006 - 12:32 PM
Pretty sure SSHatch runs Ford stud pattern.
