Hi,
I have a celica 5 sp steel case and Banjo course spline diff.
I need to replace universal joints.
Is the Universal joint at the front (yolk end) Toyota or Holden?
Regards
Dave
Uni joints for Toyota/Banjo tailshaft
_Hot_179_
, Nov 28 2006 01:25 PM
4 replies to this topic
#1 _Hot_179_
Posted 28 November 2006 - 01:25 PM
Posted 28 November 2006 - 01:50 PM
Best to take your samples shopping with you.
#3 _munro_
Posted 28 November 2006 - 10:53 PM
get a yoke that matches the holden uni ie: same cup diameter and distance between holes.
reason for this is cause you can't buy unis to fit two (brain freeze)
end of tailshaft must be identical to matching end on yoke.
this will either help you or confuse the sh#t out of you
tom
tom
#4 _Oldn64_
Posted 29 November 2006 - 07:56 PM
It depends on the yoke you have for your gearbox. As suggested above take the yoke with you and they will tell you what uni it runs, from there you can either hunt around for a yoke which has a holden uni or replace the front of teh tailshaft with the right hoop setup for the toyota uni.
The reason I state this as the early celicas ran a toyota uni whereas the later ones did convert to the holden size uni. From memory most of the coroanas ran the holden size. But check out what you have first.
Posted 30 November 2006 - 12:17 AM
That would be thanks to Mr Button no doubt. Some locally built Crowns had Holden diffs.
