I went to put some hotwires on my car to fulfill a long time dream and bugga me if one of them has got 2 pinhole leaks thru the rim itself!! Is there anyway this can be fixed or is it now destined to become a garden hose holder ?
Mags
_Pallbag_
, Nov 30 2006 06:29 AM
5 replies to this topic
#1 _pallbag_
Posted 30 November 2006 - 06:29 AM
#2 _MRNOS_
Posted 30 November 2006 - 07:39 AM
There's a few places in brisbane that could repair it for you, or try and get a inner tube fitted
Posted 30 November 2006 - 01:43 PM
Pin holes? If it is just porous (and not cracked) use either 5 min araldite or sikaflex from the inside.
Maybe have it crack tested first. Engine builder should be able to do this.
Edited by rodomo, 30 November 2006 - 01:44 PM.
#4 _Oldn64_
Posted 01 December 2006 - 07:32 PM
Crack test the rim first, if all ok then look at getting a sealant paint (like slate sealer) and paint this on the inside, this will membrane the inside and make it hold air again.
#5 _pallbag_
Posted 01 December 2006 - 07:33 PM
what sort of person does crack testing ?
#6 _Oldn64_
Posted 01 December 2006 - 07:36 PM
Two places come to mind....what sort of person does crack testing ?
1. Mag wheel repairer
2. Engine machinist.
These are the first two I would try...
PS: Engineering shops when doing suspension/steering things needs to xray bits so they would be able to point you in the right direction if need be as well..
