hey guys was just curious how much it cost around to get 2 axls from my 9 inch re drilled to a different stud pattern?
axl re drilling??
Guns n roses
, Dec 04 2006 10:37 PM
6 replies to this topic
Posted 04 December 2006 - 10:37 PM
Posted 04 December 2006 - 11:02 PM
I was quoted $150 to re drill 9" axles to Torana pattern. I hope that included the studs.
Posted 06 December 2006 - 01:59 PM
if your 9 inch is 28 spline and standard torana length and you want to go to commodore pattern you can use 2 of the short VN commodore axles
Posted 06 December 2006 - 02:56 PM
AndyCullen, Was that $150 each?
Makka, do VN commodore axles fit a 28spline 9inch? What do you mean by Short VN commodore axles?
Edit, its ok, worked it out, the diff is offsetted, which would make one axle shorter.... i had a feeling my 9inch was offset as well *fishes through the photos of the axles*
edit2
Here is a pic of my axles, one is definatly shorter..
edit2
Edited by 253ToranaSS, 06 December 2006 - 03:01 PM.
Posted 06 December 2006 - 04:14 PM
Fitting two axles the same length to a 9" will push the pinion yoke off centre by about 50mm, not a real problem but can get tight in the tunnel.
Posted 06 December 2006 - 06:08 PM
$150 was for a pair of axles redrilled.
Posted 07 December 2006 - 10:59 PM
Thanks Struggler and AndyCullen!
