Supra Box in, M20 out
4 replies to this topic
#1 _jklumpp_
_jklumpp_
Posted 06 December 2006 - 12:49 PM
Ive currently got the whole driveline out of my car, whilest the new engine was being built.
I have a full supra 'box conversion (box, bellhousing , crossmember, & tailshaft) sitting in the shed, waiting for when the m20 dies...I'm now wondering if I should throw it in when I put it all back together?
I put a tape over both boxes the other day, & it looks like the shifter on the Supra box is about 80mm further back, so I assume that the shifter hole is going to need to be enlargened.
My question is for anyone that has done the conversions - what else is needed? Is it a simple bolt on proposition, or is there a bit of work required to make it all fit?
#2 _draglc_
_draglc_
Posted 06 December 2006 - 01:42 PM
there are two shifter positions for those boxes, my celica box had the longer one, it kinda hangs over the back of the box, you can swap it with the normal one that just comes straight up out of the top of the box.
You can see a pic of the celica box i had, supra should be the same?
http://cgi.ebay.com....65664&rd=1&rd=1
Just another option if you dont want to cut the hole bigger.
The conversion is easy! Just do it now, save doing it later. Though i dont think youll be able to do it without putting the engine in first.
Got a speedo cable?
A1
#3 _big chris_
_big chris_
Posted 06 December 2006 - 02:57 PM
Hi,
there are actually 4 shifter locations I know of,
maybe more,
Picture sourced from
Gearbox info
Chris
#4 _HB1200_
_HB1200_
Posted 06 December 2006 - 03:48 PM
My supra box has a top housing, as pictured above with 6 bolts made by CRS, the shifter then bolts to that. Maybe CRS do a housing to put the shifter in the right spot for your Torana.
HB1200
#5 orangeLJ
  • 10,259 posts
Posted 08 December 2006 - 04:57 PM
so a celica box is possible to get in without enlarging the shifter hole? i have an opel four speed in my torry at the moment, but i am looking to sell the opel and upgrade, but my shifter boot is attached to my carpet, and to put in a new box with a different shifter position means new carpet, so will it go straight through the old hole?
