LJ 383 PROJECT
_dags383_
Posted 01 January 2006 - 04:30 PM
Well the original post I put up went with the old site so I have put up a new one and now added some new photos with some of the paint work done on the car. The car is now fully wet rubbed and all the panels have been put back on ready to complete the remaining paint work (Will post photos of all this stage shortly.
The car is a 72 LJ that I stripped to a bare shell, put on a rotisserie and repaired all the rust and bare metalled. All the panels have been hand straightened and then a thin layer of body filler applied and speed filed back to fill any small inperfections. I then applied 4 ltrs of polyester spray putty which was speed filed back to make every panel on the car as straight as a die. The car has had the final coat of primer which you can see from the photos has been wet rubbed.
The car will sport a fresh Fuel Injected 383 Chev (Originally from a 94 Camaro), Alloy heads, Scat Crank, Eagle Rods, Lunati Pistons, 11.1 compression and lots of shiney bits. The motor is currenty at Chevpower W.A and should be back late this month. Gearbox is a 4L60E 4 speed electronic auto which has been shift kitted and fitted with many new heavy duty parts from the US. Diff is a shortened 9" built by Phil at Final Drive in O'Conner W.A.
Some of the other things done to the car are: The steering column is from an early model Commodore that I shortened and then moved the whole column including the bracket under the dash across 3 inches so it now sits central with the dash. Not an easy job but worth the effort in the end. The only part of the column that goes into the engine bay is part of the shaft that attaches to the steering knuckle (You can see the holes for it and the bolts in the photos of the engine bay). The front end has been fully rebuilt with a Rod shop strengthening kit, nolathane bushes, HJ DBA slotted rotors and rebuilt alloy calipers and has been painted in Gun metal grey hammertone paint. I will install a full chassis strengthening kit put into the car in the near future also. There is many other small things I have done to improve the car but they would take forever to list.
Many thanks go to Sam and Cass, Dustin and Nick from Vulcan Panel and Paint for all there help so far.
The cost of the project so far has been kept to a minimum through hard work, good friends, this amazing website and Ebay. If anyone wants pointers on buying through Ebay in the USA and shipping to Australia contact me as it can save you a heap of cash.
Will post more pictures and details soon.
https://cache.gmh-to...CT/MVC-001S.jpg
https://cache.gmh-to...Sept2005019.jpg
https://cache.gmh-to...CT/DSC00385.jpg
https://cache.gmh-to...CT/DSC00393.jpg
https://cache.gmh-to...CT/DSC00391.jpg
_Flamenco_
Posted 01 January 2006 - 04:37 PM
_postal_dood_
Posted 01 January 2006 - 04:55 PM
_dags383_
Posted 01 January 2006 - 04:57 PM
This will help when and if I try to get it Licensed in the future although I think it may be beyond that stage motor wise now.
_uglybob_
Posted 01 January 2006 - 06:27 PM
Posted 01 January 2006 - 06:34 PM
Posted 01 January 2006 - 06:42 PM
_dags383_
Posted 01 January 2006 - 08:33 PM
Hi Uglybob,hey wot chassis kit did u use?? is it that 3/4 jobi from castlemaine?
The chassis kit is from Castlemaines as was the front end strengthening kit. I bought it from this very website about 18 months ago for the bargain price of 400.00 although there were 2 missing pieces + the gearbox crossmember which I bought from Castlemaines so the whole thing cost me 680.00 not bad as I am sure that they are about 1200.00 for the full set up now.
I bought the extractors for the car from Ebay brand new jet hot coated for 550.00 + a full rubber kit for an LJ 4 Door from Ebay for 350.00 and this is every rubber used on the car.
The project has been going for almost 3 years of working on it off and on and collecting all the required parts.
I am now working with a local guy on reconditioning LJ/LC Headlight surrounds, LJ Tailight surrounds and both bumpers. I cant say exactly how much it will cost and how they will turn out but I am sure a set of LJ tailight surrounds will cost no more than 150.00 per set in better then new condition.
I have a passion for these cars and helping people out with them but I do not have a passion for people that charge ludicrus prices for these sort of items. If it works I will be having some done and selling them for what it cost me as I am sure there is plenty of people out there like me building on a budget.
Cheers all for your comments it is appreciated and i will have some further pictures up soon as the car is painted and the motor comes back.
_jap-xu1_
Posted 01 January 2006 - 08:41 PM
_05-BROCKY-05_
Posted 01 January 2006 - 11:37 PM
_dags383_
Posted 02 January 2006 - 12:53 AM
Hi O5,Man that silver pops like no tomorrow, has it got some sort of pearl through it at all???. You are doing a brilliant job. BTW, exacvtly how hard was it to move the steering column over 3 inches to completely straighten it out with the dash??? I am contemplating doing this coz it irritates me having the slight lean to the left.
Moving the column was not easy as you also have to modify the pedal box to clear the column and to line up with the brake master cylinder but if you are like me and hate the offset it is well worth the effort.
The dash bracket is spot welded in a number of places inside the engine bay on the flat surface above the master cylinder. These all have to be drilled out with a spot weld drill bit. Then under the dash there is a few welds that need to be cut including the panel at the front to which the bracket is attached. I cut it along the edge of the lump that sticks out and then just rewelded it to the flat surface 3" along, filling in the holes that were left with some patches made from an old vehicle panel. Then once it is free just move it all over aligning the left edge of the bracket with the original right side of the bracket spotweld holes which should move the column over about 3 inches. If you still have a 6 in the car then I am not sure how much you need to move the bottom of the column if at all.
It is not a job that anyone should attempt without the proper tools and know how but then no guts no glory. I look at it this way if you have a welder, some metal plate, a grinder and some practical knowledge you can fix anything even you stuff up somewhere. I will see if I can get some photos of mine to show what I have done.
The paint was picked from a swatch at my friends panel shop and then mixed at the paint suppliers so I am not 100% sure what is in it but I do know i have not had it in the sun yet but when I do a photo will be posted.
Cheers,
Posted 02 January 2006 - 02:06 PM
Edited by gtrboyy, 02 January 2006 - 02:08 PM.
_dags383_
Posted 02 January 2006 - 03:31 PM
https://cache.gmh-to...CT/DSC00389.jpg
Cheers,
THE MORE YOU DO YOURSELF THE MORE YOU WILL KNOW WHEN SOMETHING GOES WRONG
_draglc_
Posted 02 January 2006 - 03:41 PM
_tuff30l_
Posted 02 January 2006 - 09:03 PM
Posted 02 January 2006 - 09:17 PM
Nice job! Its the attention to detail that really gets my attention... keep up the good work!
_dags383_
Posted 05 January 2006 - 12:34 AM
I have attached a few more photos of the car with all the panels back on albeit that I had a hell of a time getting the bonnet to line up but I finally got it sorted.
There is also some photos of some of the chrome work that has started to roll in for the car.
I am also looking for some chrome plated pieces like bonnet latches etc that are in new condition. I seen them on Ebay a few times last year but not for a while. So if anyone has something thay may want to sell let me know.
Cheers,
Posted 05 January 2006 - 12:43 AM
The one Cassie was trying to sell you ?
I'm thinking of 383 for my hatchback (datsun project on hold again)
_dags383_
Posted 05 January 2006 - 12:52 AM
I ended up with the Scat 9000 crank, eagle rods and Lunati forged racing pistons. Originally it was going to be the eagle crank but they had no single piece rear main seal cranks in Australia so I had to upgrade. The only problem with the eagle rods is that the square shoulder has to be clearanced for the cam etc.Hey Dags what stroker kit did you go with in the end ?
I have a question for you as i am now starting to think ahead to my braking system and need to work out which master cylinder, remote booster etc to use. I almost bought one of the new Wilwood 1" master cylinders from the US but stopped as I am not sure if it is the correct item. Should I drop around the shop?
Cheers,
_NRV051_
Posted 05 January 2006 - 06:06 AM
#21
_NRV051_
Posted 05 January 2006 - 06:07 AM
#22
_dags383_
Posted 26 January 2006 - 02:29 AM
Well the car got painted on the weekend and it has come up a treat as you can see from the pictures. The body is straight and the paint just blinds in the sun. It has come out so flat that i dont think it will need a wet rub to flatten it.
Next week it goes on the hoist to clean up and spray the underneath and i will fit the chassis kit. The motor is due at the end of next week with the heads and EFI manifold ready early next week also.
_MRNOS_
Posted 26 January 2006 - 06:02 AM
#24
_05-BROCKY-05_
Posted 26 January 2006 - 10:06 AM
#25
_draglc_
Posted 26 January 2006 - 11:47 AM
there are a few chrome bits on ebay at the moment.. got some links for ya
http://cgi.ebay.com....me=STRK:MEWA:IT
thought there was more, have a look around.
A1
