i am setting up an lj style front end with holden hq/z calipers and discs
what i would like to know is what master cylder can i use with out having to use a brake booster yet still retain a soft yet firm pedal (do not like the look of the booster)and i do not want to use a remote booster ...........
help needed with brakes
_ultrabluea9x_
, Dec 23 2006 08:49 PM
2 replies to this topic
#1 _ultrabluea9x_
Posted 23 December 2006 - 08:49 PM
Posted 24 December 2006 - 12:21 AM
With the short pedals I recall on the LC/LJ I'd suggest a 7/8" tandem cylinder
To retain the original look you would have to get someone to double sleeve a standard 1" down to 7/8 and make pistons to suit
I would first try a simple easily avail 7/8 unit like a Datsun one to see if the feel and displacement are adequate before you spend alot of money making a custom cylinder. This would mean abit of muching about with pipes and maybe using some sort of adaptor plate on the firewall to mount it. But its probably worth trying first
If the 7/8 is too soft then a 15/16 would be the next step up
You'll probably find the original 1" one abit heavy
Posted 24 December 2006 - 07:39 PM
I drove mine around with no booster,the pedal feel is fairly solid as you would expect.I asked the local brake shop if they could resleeve the m/cyl & fit a different piston to suit just to see if it would work but they didn't want to do it as I also had rear discs so it may still have been a mismatch according to them.
