lh brake problems
#1 _fathr6_
Posted 26 December 2006 - 05:53 PM
Posted 26 December 2006 - 06:09 PM
#3 _fathr6_
Posted 26 December 2006 - 07:34 PM
Nope, had a wheel alignment done.If you drive along a flat road and let go of the steering wheel, does it pull left without using the brakes?
#4 _DocDamage_
Posted 26 December 2006 - 08:46 PM
Posted 26 December 2006 - 11:16 PM
Do your tyres have flat spots or delamination?
#6 _rorym_
Posted 27 December 2006 - 07:40 AM
#7 _fathr6_
Posted 27 December 2006 - 07:47 AM
Posted 27 December 2006 - 08:19 AM
i would check them again
it only takes a split second for something to break
dave
#9 _Rob 5000_
Posted 27 December 2006 - 09:52 AM
#10 _fathr6_
Posted 27 December 2006 - 06:00 PM
Posted 27 December 2006 - 09:45 PM
#12 _devilsadvocate_
Posted 27 December 2006 - 10:43 PM
You haven't listed the brake pads?I have changed rotors, calipers, brake lines, proportioning valve and blown out the steel brake lines. Im thinking master cylinder, booster is the only thing left after that.
Posted 27 December 2006 - 11:40 PM
I agree, the last time I had a Torana that pulled to the left under brakes I found the right caliper had seized.Maybe the right isn't working too good? You say you have changed calipers but were they recoed? Hoses have been know to deteriorate inside and can block when brakes applied starving pressure to a particular wheel.
I would suggest that there may be a problem with the right side not braking sufficiently... or at all...
#14 _fathr6_
Posted 28 December 2006 - 08:09 AM
#15 _rorym_
Posted 28 December 2006 - 11:07 AM
#16 _fathr6_
Posted 28 December 2006 - 04:55 PM
#17 _torana_
Posted 28 December 2006 - 05:34 PM
Tell us how you go.
cheers julian
#18 _fathr6_
Posted 28 December 2006 - 06:29 PM
Posted 28 December 2006 - 06:55 PM
#20 _devilsadvocate_
Posted 28 December 2006 - 11:11 PM
Sounds like a line from a James Taylor song............If you havent got a friend use a length of wood jammed against your seat and check the wheels.
Just as a tid bit, having to regularly check the brake lights when attaching a trailer to the UC, instead of jamming a friend or piece of wood between the pedal and the seat(this can be tricky), I stick something like the head of a holden key or a fuse between the arm/leg of the brake pedal and the bracket up near where the brake lamp switch is to hold the pedal down. Im sure the bracket here would be strong enough to hold something if you pushed the pedal down very hard.
In relation to the brake prob, a weakened front suspension could cause it to veer left under braking, though Im not sure how that could explain how the wheel may lock up easier.
Something to shed more light on it, what happens when you do it in reverse? Does it lock up, which way does it veer?
#21
Posted 28 December 2006 - 11:27 PM
but if your shocks, bushes and or springs are worn, change them anyway, i cant stand my fathers view on cars, its like well its going and i dont drive like you do, its not the point, why drive a car, especially a torry, and not maintain it.
#22 _SS Hatchback_
Posted 04 January 2007 - 10:34 PM
