Hi have a question regarding the size diffrents of the lc gtrxu1 / gts steering wheel. i have two wheels
one lc gtr in black which is 13.1/2 inch I.D , and a brown wood grain pattern
gtr / hk-gts wheel which is 14.1/2 inch inside diameter . i was told that the steering wheel sizers had some relation to the tyer/ wheel size of the car ? so lc gtr- xu1 would have the small size . if this is right a small size wood grain,brown lc gtr wheel would be harder to find than a black one , any iders! dr terry should no
LC GTR-XU1 WHEEL
_dave720gtr_
, Jan 01 2007 04:24 PM
6 replies to this topic
#1 _dave720gtr_
Posted 01 January 2007 - 04:24 PM
#2 _gtr161s_
Posted 02 January 2007 - 01:02 PM
i've never compared the 2 models but always thought the were the same.
Why would holden make 2 different size steering wheels at the same time, considering the manufacturing climate it wouldnt have been cost effective
#3 _dave720gtr_
Posted 02 January 2007 - 03:16 PM
Well as i said i have two original holden wheels , not repo
one is 14.1/2 I.D,This wheel came with a LC gtr was in the boot , And the black one which is 13.1/2 inch I.D it came off a ht ute with gts gear on it .
if any one gets the chance to check there wheel I.D let me no what size
of any gts, lc gtr-xu1 wheels.
#4 _smelvin_
Posted 05 January 2007 - 03:06 PM
This won't help you much Dave, but it's what I've got. I believe it's the original wheel off my LC GTR (not XU1) as it came with the car, but I can't be 100% sure. This wheel has a black rim and if I butt the tape up inside the rim and measure through the centre to inside the rim again it measures 14 inches exactly. Can only find one wheel assembly in the parts manual for the GTR and as the XU1 is a sub model of the GTR I guess they came with the same wheel. Sorry to add more confusion but that's what I found.
#5 _dave720gtr_
Posted 05 January 2007 - 08:49 PM
Ok thanks mate i will dubble check to see if it is 14 ' i know one wheel fitts inside the other .cheers
#6 _1973bathxu1_
Posted 07 January 2007 - 09:06 PM
the woodgrain is probebly off hk monaro they are slightley larger they look identicle until you put the 2 wheels together
#7 _dave720gtr_
Posted 08 January 2007 - 11:07 AM
OK thanks!.. thats what i thourght
