what rear shocks????
#1 _2wild4u_
Posted 01 January 2007 - 08:55 PM
#2 _Bomber Watson_
Posted 01 January 2007 - 09:16 PM
not adjustable up and down, but they are adjustable (soft to stiff). havnt been able to try them yet as the cars in bits but they should work for you, much cheaper to.
Posted 01 January 2007 - 09:21 PM
stiffer shock will only give you problems if not matched to the spring.
Posted 01 January 2007 - 11:35 PM
Dave
#5 _rorym_
Posted 02 January 2007 - 08:13 AM
Posted 02 January 2007 - 06:02 PM
You need to take these off the car every time you wish to adjust them.competion engineering in the u.s. which are adjustable 3 ways either 70/30 60/40 50/50 ?
you take them off, unlock them, turn the body, lock them up then refit them.
There is only 3 settings so you only have to take them out 3 times and check each setting and pick which suits your car best. I think there about $40US or even cheaper?
#7 _Monkey_
#8 _NVMYLH_
Posted 02 January 2007 - 06:34 PM
#9 _2wild4u_
Posted 02 January 2007 - 07:50 PM
#10 _timbotorrie_
Posted 02 January 2007 - 08:19 PM
you wont get much traction with TAs and a heap of grunt! i hated my old TAs, no traction at all!
Edited by timbotorrie, 02 January 2007 - 08:21 PM.
#11 _rorym_
Posted 03 January 2007 - 03:45 PM
#12 _2turbohz_
Posted 03 January 2007 - 07:43 PM
which sorted the axle tramp and suit the lovells springs nicely
Then i discovered they only make Gas Adjust for the rear
all they offer for the front is their premium oil shocks
Which Have good rebound damping but no compression
damping seems silly backs nice and tight with fronts bouncing
around alright in a woman but not the lj!!
#13 _@milco@_
Posted 22 January 2007 - 11:50 PM
how much did they cost?I got a set of KYB Gas Adjust shocks for the back of the lj
#14 _2turbohz_
Posted 23 January 2007 - 06:11 PM
P/no 553041 If that helps at all?
Cheers Chris
Posted 09 February 2007 - 03:43 PM
Not sure on the part number but they said there was only 1 type of KYB's for an LX.
