Swap Trimatic for turbo 400
12 replies to this topic
#1 micklx
micklx
  • 1,785 posts
Posted 05 January 2007 - 10:41 PM
Does anyone know if this is an easy swap?
Can the same tailshaft be used if you change the front yoke?
How about the xmember ?
#2 tinkers
tinkers
    Admin
  • 3,796 posts
  • Name:Kerri
Posted 05 January 2007 - 10:59 PM
Bellhousing is different, need turbo patten but I think it is just the bolt holes that dont match up.
Xmember is different
cant remember about the tailshaft
#3 _Oldman_
_Oldman_
Posted 06 January 2007 - 12:41 AM
block bolt pattern incorrect & turbo i believe takes more HP to run & unless you're shasing the overdrive not worth the hassle
#4 _T0rana_
_T0rana_
Posted 06 January 2007 - 03:32 AM
Also some turbo boxes have the long tail, like mine, which requires shortening of the tailshaft, iv been told the short tail boxes dont require any tailshaft mods. the splines are the same as holden.
#5 gtrboyy
gtrboyy
  • 3,149 posts
Posted 06 January 2007 - 12:27 PM
The one I have also has a switch to kickdown.
#6 _johndefender_
_johndefender_
Posted 07 January 2007 - 09:01 AM
Whilst we are on this topic, do you need another rear engine mount (transmission mount)? I had a T400 on a 308 many years ago and have forgotten. I can remember though an adapter plate.
Thanks :rolleyes:
#7 _bodallafella_
_bodallafella_
Posted 07 January 2007 - 12:44 PM
You will need:
Block redrilled to Turbo Pattern
Slip Yoke
Shorter Tailshaft
X-member
Trans Mount
Converter
It will probably cost around $250 to get the block redrilled as some of the Trimatic holes need to be filled first and the dowells need to be relocated and changed to 1/2". You will need a block with a rope rear seal as the neoprene seal blocks don't have enough meat around the dowells.
The Turbo 400 is still a 3 speed with no overdrive so this conversion would be for strength only. The swap to a Turbo 350 is easier as it uses the same tailshaft and yoke but you still need the block redrilled.
#8 micklx
micklx
  • 1,785 posts
Posted 07 January 2007 - 01:47 PM
How do you tell the difference between a 350 and 400 ?
#9 _bodallafella_
_bodallafella_
Posted 07 January 2007 - 02:22 PM
The 350 pan is square with one corner cut off and the 400 pan is shaped like a chicken McNugget.
#10 _v8slrtorana_
_v8slrtorana_
Posted 07 January 2007 - 02:48 PM
You may find this link helpfull.
tranny info
Also you will need a cross over uni for the turbo 400 yoke. Unless your are very lucky to find the early HJ t400 yoke.
I did not shorten my tailshaft when i went from trimatic to turbo 400
Edited by v8slrtorana, 07 January 2007 - 02:51 PM.
#11 lakeside
lakeside
  • 2,703 posts
  • Car:LC SBC
Posted 07 January 2007 - 08:03 PM
They make an adapter plate which is about 1/2 inch thick. Then you have to space the covertor the same. They work if you drive like a old lady, they come loose. Buy another block. You can pick up a T350 and a little bigger than a tri-matic, and the T400 looks like it belongs in a truck
#12 gtrboyy
gtrboyy
  • 3,149 posts
Posted 07 January 2007 - 11:56 PM
I was told that the m20/trimatic slip yoke will fit a th350/th700 but not a th400 as it has a much larger output shaft.
#13 _HatchmanSS76_
_HatchmanSS76_
Posted 09 January 2007 - 12:04 AM
Stay away from tha adaptor plate route unless you have your torque converter made modified to suit. I ran an adaptor plate on my old 2fluffy with Turbo 350. The bolts spacer and nut pulled out the mount on the torque converter and flex plate on 2 out of the three at around 3500rpm on the highway. One came out completly and nearly punched a hole trough the tunnel where my left leg was. The othe two were all cracked and bearly hanging on. If you really want the Turbo box behind your motot you could get the Torque Converter modified/beefed up at the bolt up position.
If your serrious I could dig through all my shit and take some pics of exactly what I mean. What I had done has no chance of breaking and is a great mod as long as you don't want to keep changing converters as it not interchangable.
