torque converters
9 replies to this topic
#1 _Drag lc_
_Drag lc_
Posted 12 November 2005 - 10:10 AM
does anybody know where is the best place to get a good quality converter to suit 6cyl trimatic with a stall speed of around 1500rpm?
#2 Peter UC
Peter UC
  • 765 posts
Posted 12 November 2005 - 10:13 AM
I thought standard convertors would have a stall speed of about 1500rpm
#3 _pro386_
_pro386_
Posted 13 November 2005 - 07:30 PM
Just try a converter shop. I got a 4 cylidner gemini converter done for my torana a couple years ago and it was modified to stall up to 2500 i think it only cost about $270
#4 _torana05_
_torana05_
Posted 13 November 2005 - 10:26 PM
Andrew, Contact Dave at Queensland Convertors at Stafford on 3356 6066. I have used his convertors before with no problems.
Andrew2 :)
#5 _draglc_
_draglc_
Posted 13 November 2005 - 10:29 PM
A2, not me :P
A1
#6 _LX406_
_LX406_
Posted 15 November 2005 - 11:15 AM
1500 rpm on a converter is lower than standard. Is it for towing or something?
#7 Stedz_lc
Stedz_lc
  • 1,144 posts
Posted 17 November 2005 - 08:32 PM
1500!? U reckon i think mine stalls around the 1100 THINK i really need a stally too cant idle in gear to nice :| What did u go? What did it set u back?
Stedz
#8 _[BOTTLEDUP]_
_[BOTTLEDUP]_
Posted 17 November 2005 - 08:52 PM
Get a Gemmi converter if you want cheap, they'll stall to around 2200-2500 on a 6 dependant on the torque output.
Otherwise spend the dosh and get a brand new one from Dominator or similar.
#9 _pallbag_
_pallbag_
Posted 30 July 2006 - 09:50 AM
How do they work ?
eg. If I have 2500 stall, wouldnt this mean it doesnt hook up till engine reaches 2500rpm ? And on the highway would it always have to be in or above the 2500rpm rev range to be working ? Or have I got this all wrong ?
#10 TerrA LX
Posted 30 July 2006 - 07:06 PM
it works just the same as your standard one, it just slips a little more up the rev range. a little like slipping the clutch when you have a big load, only that it will be slipping constantly under 2000 instead of just off 1000.
