Now, that plan is to use the 202 crank and rods in the 186 block, because apparently the cranks are better balanced then the red cranks, and well, starfire rods; how can i refuse
Not sure what pistons i'll be using at the moment whether from the blue or red motor. Be using my yella terra head, ill be getting some straight cut timing gears, bit of a cam. In the department of manifolds, ill be using my 2 barrel redline manifold with a holley 350, which i can always later change for the WW2 strommy later on, and also its got extractors. Later on i'll be putting YT rollers on the top. Thats the plans for the moment. Tell us what you guys think. Cheers.
