Camshafts (holden six)
#1 _UCV80_
Posted 12 November 2005 - 03:21 PM
i want one that will idle nice and lumpy, and goes well in high revs
my engine is a 186 , bored 60thou, blueprinted ect ect, should rev over 6k
which one do you guys recon??
here is a link
Crow Cams
nathan
#2 _Yella SLuR_
Posted 12 November 2005 - 09:29 PM
Try this one, although I think it is a fax back setup, although I might be wrong!
Crane Online Cam Selection
#3 _[BOTTLEDUP]_
Posted 12 November 2005 - 10:50 PM
I thought that was going to be Sarsh's engine...
Need more details before I can help you choose a cam... Give me the specs on everything:
Cyl head type,
Inlet and exhaust valve sizes
Compression ratio
Intake manifold
Carburettor
Exhaust
RPM range
Auto/Manual
Diff ratio
Vehicle weight
Fuel type
Intended use
Roller Rockers?
Valve springs?
#4 _1QUICK LJ_
Posted 13 November 2005 - 12:04 AM
#5 _Keithy's_UC_
Posted 13 November 2005 - 07:22 AM
I have a 186 (now) just finished rebuilding it, have got some hardcore internals and find that "Precision Dynotec XU-1" Cam is perfectly what you have described. Im using it in mine and it lumps over at idle, revs nicely and still drives as if you were running a standard cam (very smooth power delivery).
Ive only got 150kms on the new motor, so i havent flogged it yet (been up to 4000rpm, but no higher), but it likes to rev - it wanted more revs than what i was brave enough to give it!
I fly home from work on thursday night - ill jump on MSN messenger and send you a video clip with sound of mine running! It sounds awesome!
Keith
#6 _UCV80_
Posted 13 November 2005 - 09:08 AM
Looks like i need to sort the cam out last
here my list so far, not finished though
186 block
60 thou pistons flat top
Starfire rods
JP straight cut timing gears (JP 5994)
Harmonic balancer
Big end bearings Size:
Crank bearings Size:
Cam bearings Size:
Camshaft
Gasket kit
Hydraulic lifters
350 Holley
pacemaker extractors, 2 1/2" exhaust
Head will be a yella terra (no info on it yet) but i do want a very good highcomp one
ill have to build this engine then decide on the cam
but i do want a very tough engine for street use, even if its a bitch in peak hour traffic.
thanx guys.
cant wait to see some of those vids
#7 _[BOTTLEDUP]_
Posted 13 November 2005 - 12:10 PM
For the record, in the Crow selection the 35604 is the XU1 grind, and 35616 is the 'Bathurst' XU1 spec. Both for 202s.
I'd go with 1QUICKLJ's recommendation of a 35802, you'll also need:
4823 valve springs
11707 retainers
11703 collets
I'd recommend R/Rockers Street Terras will be fine, and also get some decent pushrods, Crow part# PR9515.
Let me know if you need any of them.
Posted 13 November 2005 - 01:23 PM
i wasnted something a bit bigger, but not a cam that woudlnt kick in untill like 300rpm, as i wont be thrashing the motor! its just a nice daily!
Although a lumpy idle would be nice !
#9 _kb3310_
Posted 13 November 2005 - 02:05 PM
#10 _UCV80_
Posted 14 November 2005 - 09:46 AM
is a 9:1 head compression high, ? was lookin at a yt head for sale
#11 _[BOTTLEDUP]_
Posted 14 November 2005 - 11:03 PM
#12 _T0rana_
Posted 17 November 2005 - 05:57 PM
#13 _[BOTTLEDUP]_
Posted 17 November 2005 - 07:20 PM
Posted 17 November 2005 - 08:22 PM
U want a lumpy idle take a vacumn line off
#15 _[BOTTLEDUP]_
Posted 17 November 2005 - 08:48 PM
But to answer your Q Sarsh no-one can tell you without a grind number off the cam
Posted 17 November 2005 - 09:48 PM
