Are the disc brakes the same from the 6 / 8 ?
And is it a big job to put HZ brakes on,is it a matter of removing the stub and disc and caiper as an assemble. are the ball joints the same, will this affect wheel alignment?
Brakes
_Barman_
, Jan 05 2006 03:58 PM
3 replies to this topic
#1 _Barman_
Posted 05 January 2006 - 03:58 PM
Posted 05 January 2006 - 05:56 PM
6/8 brakes are the same except the V8's got a double diaphragm booster.
Easy to swap them for HQ but you need special steering arms from Harrop with the HQ stubs and you will most definately need a wheel alignment as the torana and HQ stubs have a different KPI - so a fair difference in the number of shims to achieve the same suspension alignment settings.
Balljoints are the same.
#3 _CHOPPER_
Posted 05 January 2006 - 05:57 PM
#1 6 and 8 cyl LH - UC have the same front disc ( DBA 010 ) 6 and 8 cyl HQ - WB have the same front disc ( DBA 014.#1 Are the disc brakes the same from the 6 / 8 ?
#2 And is it a big job to put HZ brakes on, is it a matter of removing the stub and disc and caiper as an assemble.
#3 Are the ball joints the same?
#4 Will this affect wheel alignment?
#2 To install HZ brakes on an LH is as you posted. However, it is advised to use Harrop steering arms ( $297/pair ) to avoid bumpsteer.
#3 Yes.
#4 Camber will be altered by 2 degrees, so an alignment is needed.
#4 _Barman_
Posted 06 January 2006 - 08:07 PM
Thanks guys. If im going to make go harder i want be able slow it down too!
