I've heard you can get a repair kit for starter motors
mines a red six one and i've broken the plastic solanoid while undoing the power connections.
what do you get and can you do it all yourself?
starter motor
_wildsix_
, Jan 06 2006 02:03 PM
6 replies to this topic
#1 _wildsix_
Posted 06 January 2006 - 02:03 PM
#2 _J&S Racing_
Posted 06 January 2006 - 04:56 PM
You can buy the solonoid cap maybe from repco and it's very easy to change over, just take out the 2 screws and un-solder the 2 wires to get it off when your putting the new one on screw it down before you solder the 2 wires.
#3 _wildsix_
Posted 06 January 2006 - 07:46 PM
thanks for that, will look into it.
#4 _draglc_
Posted 06 January 2006 - 11:26 PM
it is very easy, ive had a few high torque ones go, cheap crap, i just swap bits over from spare starters, works fine now
#5 _wildsix_
Posted 12 January 2006 - 06:18 PM
part number gb900 bosch soleniod, worked a treat
#6 _dazzaslr308_
Posted 12 January 2006 - 06:48 PM
nothing too complex in repairing ur starter, just make sure u have a soldering iron nearby as u will need to use 1 for the solenoid cap and brushes if they need changing also.
#7 _Yella SLuR_
Posted 12 January 2006 - 09:29 PM
Make sure you use loctite on those solenoid cap screws, they have a habit of working their way loose. I had to temporarily screw mine back in to allow me to undo the battery lead, would of busted it otherwise.
