A guy I know with a long history of playing with Torana's got on this web site the other day, & found my post & picture about dropping the top arm 1"
He tells me this is wrong, and that it should only be 5/8"!?!?
He says;
-Car will bump steer under brakes (toe out)
-Wont be able to run enough caster or toe in to correct
-Russel Skaife tried this on Marks Torana in the 80's (unstable)
Any posts that I have seen on this site in regards to this mod have always stated 1", so can someone please confirm?
I have just put the engine & crossmember back in the car, so I'm hoping it doesn't have to come out again - I was just trying to get some reasonable camber on the front wheels last night (rough enough to get it to the aligners), but seems as though it's still in negative camber, with about 20mm of wedges in there.... so now I'm worried....
Original post & picture here:http://www.gmh-torana.com/forums/index.php?showtopic=9666&st=15 (for some reason can't get a link to work...)
Edited by jklumpp, 07 February 2007 - 06:57 PM.
