changing to hq pattern
#1 _Bomber Watson_
Posted 07 January 2006 - 09:04 PM
i see a few options, one is weld up the holes in the hub and re drill them further out (dun like this idea much), two is look around for a conversion hub...that takes the standerd lj brake rotor and has hq pattern. any idea where i could get something like this? three is convert to hq front stubs and breaks...dun really wanna do this though cause i just went right through my front brakes.
so wahts the verdict...anyone got some good tips??? im looking into this cause i wanna run weld pro stars and you can only get these in hq and ford patter. if i go this way i'll put a borgie diff in the back...commy pattern is near enough *flamesuit on*
#2 _CHOPPER_
Posted 07 January 2006 - 09:16 PM
#3 _Yella SLuR_
Posted 07 January 2006 - 10:12 PM
Hope you know what I'm saying! I can see it, but can't explain it.
#4 _Bomber Watson_
Posted 07 January 2006 - 10:45 PM
you can see what i'm ranting about here...just
so fud has the closer pattern...i honestly thought that hq was 4.5 and ford 4.75. i'll have a look into it that way then.
Posted 08 January 2006 - 12:21 AM
I believe dragway make a prostar lookin wheel well they did mates got em on his torrie in torrie pattern
CHeers
Stedz
#6 _Bomber Watson_
Posted 08 January 2006 - 12:31 AM
#7 _Yella SLuR_
Posted 08 January 2006 - 08:45 AM
Guy at the shop wouldn't say how legal it was. Think I'd prefer to just change over properly.
#8 _CHOPPER_
Posted 08 January 2006 - 12:34 PM
#1 I knew about the seperate hub, I just wasn't sure if they could be bought new and un-drilled. The spacers that Pat spoke of which alter stud pattern are legal in VIC. Unsure about other states. Which is why I didn't mention them. If they are legal in QLD, expect to pay $620 for a set of 4. Plus postage if applicable.#1 you both sem to be foregetting, lc/lj's have a seperate hub to the disk. the disk bolts onto the outside face of the hub (where the wheel goes on) with bolts in between the studs. ie pats suggestion not possible.
#2 so fud has the closer pattern...i honestly thought that hq was 4.5 and ford 4.75. i'll have a look into it that way then.
#2 Trust me, I'm right.
#9 _Bomber Watson_
Posted 08 January 2006 - 06:26 PM
#2 trust me, i know your right. i just said i thought it was the other way around.
Posted 08 January 2006 - 06:56 PM
Best you could hope for is these type of trailer hubs
http://www.trojan.co...geID=2145834349
But you would need to contact them with regard to offsets,bearing sizes (should be ok) stud pattern for wheels, stud pattern for disc.
The original hubs could be cast welded up and redrilled. If you can find a suitable person to do them but they would then need x-raying to make sure they are not weakened. Probably a few crank hardening tricks would be in order too - shotpeen,magnaflux etc etc.
Would cost less to buy the dragways.
Posted 08 January 2006 - 10:25 PM
Then put a Ford pattern Nine inch in the back
#12 _CHOPPER_
Posted 08 January 2006 - 10:51 PM
cant you use an adapter to fit P76 discs?
He could except for...
i see a few options.....three is convert to hq front stubs and breaks...dun really wanna do this though cause i just went right through my front brakes.
Posted 09 January 2006 - 03:53 PM
Good luck lil boi
#14 _Bomber Watson_
Posted 09 January 2006 - 07:03 PM
that said a mate has some 14x7 and 14x8 centerlines he wanst to unload...they look so god damb tough but won't fit over the disks i was gona have on the back. so i'm thinking i might stick with volvo diff (torry pattern) and run torana axel tubes and drums on it....so i can fit the centerlines on. did want back disks though.
datto, while i got your attention, know of any quick disk brake conversions for torana axel tubes that will fit under 14's??????
cheers for ya help so far guy's.
Posted 09 January 2006 - 08:29 PM
And Commodores ran 14" wheels with disc rear.
#16 _Bomber Watson_
Posted 09 January 2006 - 09:56 PM
Posted 09 January 2006 - 10:12 PM
This has the handbrake mech in it
Plus the bracket to hold the caliper
#18 _Bomber Watson_
Posted 09 January 2006 - 10:19 PM
cheers heeps mate, as always you have been invaluable
