harness bolts
10 replies to this topic
#1 _brett_32i_
_brett_32i_
Posted 03 March 2007 - 07:13 PM
got a harness for the old girl but the eye bolts that came with it don't suit.
rang rev racegear and they reckon they dont have a bolt for a torana.
has anyone found an easy solution for this? should i be able to get an eye bolt from a bolt shop, or do i need to fab up a bracket?
#2 _Monkey_
_Monkey_
Posted 03 March 2007 - 07:25 PM
I bought eye bolts from revolution...20mm long threads and 45mm long threads.
They threaded into the original belt bolt holes in my lj.
#3 _rorym_
Posted 03 March 2007 - 07:58 PM
Dont get them from a hardware shop..there are correct types to use.
#4 _brett_32i_
_brett_32i_
Posted 04 March 2007 - 08:03 PM
are lj bolts same as lh-x-uc??
#5 dattoman
  • 16,471 posts
Posted 04 March 2007 - 08:07 PM
You can't mount a harness of the original seat points anyway
Theres proper angles to take into consideration so you don't crush your spine in an accident
Or am I missing something here
#6 _Monkey_
_Monkey_
Posted 04 March 2007 - 08:19 PM
^The front two i mounted in the original holes
the back two i mounted on the parcel shelf.
#7 _brett_32i_
_brett_32i_
Posted 05 March 2007 - 07:00 PM
4 point harness, bottom 2 in original holes. top straps go to lower rear holes (crossed over)
it looks like the bolts are 1/2" unc. rev race and everyone else only has the 7/16" unf.
i can get forged eyebolts to suit from a crane joint.
#8 _Monkey_
_Monkey_
Posted 05 March 2007 - 07:09 PM
^What do you mean "top straps go to lower rear holes "??
and i dont think your supposed to cross the shoulder straps.
#9 _Yella SLuR_
_Yella SLuR_
Posted 06 March 2007 - 03:48 AM
A road application, which is going to be a compromise.
In a proper set up these days they recommend connection to the horizontal bar on the main hoop to minimise length and flex in the straps, recommended range is between horizontal and 30 degrees from your shoulder height for the top straps running back.
With only a 4 point, it ain't going to stop you submarining anyways. In a street car, I call fitting a harness as false sense of security, spose just so it looks good, fast, or whatever!!!
The ideal companion for these are race styled seats that you pay a fortune for that are not certified to the Australian Standard.
Edited by Yella SLuR, 06 March 2007 - 03:50 AM.
#10 _redrana_
_redrana_
Posted 14 September 2007 - 04:08 PM
I'm dragging this thread up to see if anyone managed to find a supplier of UNC eyebolts for fitting harnesses to LH/LX Toranas? I've also found that so far all I can get is 7/16UNF bolts. Any ideas :spoton:
#11 rodomo
  • 17,999 posts
Posted 15 September 2007 - 12:32 AM
If your in Melb? there is a place on the Hume Hwy in Campbellfield near Barry's rd I think that deals in lifting gear e.g. chains and slings e.t.c.
