Is this just the flasher module or could it be somehting else, they were working fine when i took the dash apart but now flash too fast.
were is the flasher usually found on an LH??
nibbsy
blinkers flickin too fast
_nibbsy_
, Mar 13 2007 08:08 PM
6 replies to this topic
#1 _nibbsy_
Posted 13 March 2007 - 08:08 PM
#2 _why-psi_
Posted 13 March 2007 - 08:15 PM
you got a globe out? or the indicator light on the dash?
Posted 13 March 2007 - 08:17 PM
there is a clamp on the right hand side of the steering column.
its up a bit out of sight,in amongst the wires and brake pedal spring.
#4 _nibbsy_
Posted 13 March 2007 - 08:18 PM
actually i think there is a globe out, how did i not think of that.
Both the lights on the dash work, i only have one bulb out, the right rear i believe, would this affect the left circuit also?? cos this one blinks fast too
Sounds like a globe out or a dodgy earth!
Did I say that out loud?
Must be learning something?!
#6 _why-psi_
Posted 13 March 2007 - 08:21 PM
havin a globe out would make it flash fast check ur globes an earths
Posted 13 March 2007 - 11:48 PM
maybe you should swap with makka, his is blinking heaps slow! like a UC in a race!
