my fuse panel is shagged, all the terminals rusted up.
has anyone seen new ones available anywhere?
or are early commo's the same/similar?
fuse panel
_brett_32i_
, Mar 19 2007 09:24 PM
6 replies to this topic
#1 _brett_32i_
Posted 19 March 2007 - 09:24 PM
Posted 19 March 2007 - 09:45 PM
Early Commodores use ceramic fuses.
#3 _Flamenco_
Posted 19 March 2007 - 11:08 PM
Best bet would be the wreckers, Should be one of the few things still remaining on torries there (apart from dented bumpers etc!)
#4 _brett_32i_
Posted 20 March 2007 - 09:11 PM
instead i bought 2 x narva blade type fuse fails which hold 6 fuses each. mounted them on an aluminum panel the same size as original fuse panel. looks pretty neat...
Posted 22 March 2007 - 10:46 PM
I used the same type, but 8 fuses, when I rewired the Rangie and have one to fit to the Commodore soon. They are neat and easier to follow your wiring later.
Edited by rodomo, 22 March 2007 - 10:55 PM.
Posted 22 March 2007 - 10:55 PM
Is there a way to restore these rusted fuse panels (terminals)?
#7 _Flamenco_
Posted 23 March 2007 - 01:04 AM
You could but it would involve dismantling it and buying new spade clip terminals and soldering a few bits together. Probably easier to get a secondhand one unless you're miles away from a wreckers...
As far as terminals go I think only a wire brush or files could help rust on them - the fuse 'clips' would just be throw away's (they aren't much new anyway).
Edited by Flamenco, 23 March 2007 - 01:06 AM.
