hey guys iv seen this front sway bar on ebay
http://cgi.ebay.com....1QQcmdZViewItem
iv been wanting to get one for a while but i wanted to know if there where differnt types
as in do some have differnt mounts or are there any better then others?
any feedback would be appreciated.
ben
LC/LJ front sway bar
_uglybob_
, Mar 23 2007 07:11 PM
10 replies to this topic
#1 _uglybob_
Posted 23 March 2007 - 07:11 PM
#2 _LoneOranger_
Posted 23 March 2007 - 09:34 PM
Ben, I have a 22mm Selbys (Whiteline) bar on my car.
It mounts up the same as this bar, but has a dip on the left side for clearance if you have extractors on your car.
John.
John.
#3 _73LJWhiteSL_
Posted 23 March 2007 - 10:59 PM
22mm Whiteline Swaybar mounted under the LJ.
This is the 'bump' under the extractors in the bottom right hand side of the pic.
Heres a better shot of it mounted. The front is mounted on the bottom of the castor rods.
And yes I know, I have oil leaks
They are really good. Car corners very flat with that one in place. Very happy with it.
Steve
Steve
#4 _LoneOranger_
Posted 24 March 2007 - 08:29 AM
Yep Steve,
That's the bar.
Ben, The sway bar in the picture appears straight.
You may have clearance problems if running extractors.
Best to check with the seller.
John.
That's the bar.
John.
#5 _dickiep_
Posted 24 March 2007 - 12:48 PM
im currently running a shelby sway bar. does anyone with one have clearance issues on speed bumsp, dips, just about anything?
#6 _LoneOranger_
Posted 24 March 2007 - 12:51 PM
No problems with mine.
And it is running lower than standard height. about 1 1/2 "
John.
John.
#7 _dickiep_
Posted 24 March 2007 - 01:00 PM
i just double checked mine and it is bout 1.5-2 inch off the ground stationary on a level surface. i cringe everytime i go over a speed bump or dip
#8 _73LJWhiteSL_
Posted 24 March 2007 - 05:37 PM
My sway bar comes out about 9cm off the ground under the extractors. I just have to watch out for the really tall speedhumps. Mine only scaps on about 2 or 3 in 10.
Steve
Steve
Posted 24 March 2007 - 06:47 PM
Hi
Don't most State regulations specify a minimum ground clearance of 100mm (4 inches)?
Bazza
Bazza
Posted 25 March 2007 - 12:16 AM
i have one similar to those, on my LJ scrapes down on some very large speedhumps but nothing major. it has a flat section there now instead of round
#11 _uglybob_
Posted 30 March 2007 - 06:56 PM
ok then no worries thanks guys! ill go get some selbys then. 22mm is the way to go then is it?
thanks fo the feedback
ben
ben
