thermo fans
#1 _uglybob_
Posted 01 April 2007 - 04:34 PM
any feedback would be apprecated
Ben
#2 _heppy_ss_76_
Posted 01 April 2007 - 05:17 PM
Posted 01 April 2007 - 08:16 PM
#4 _73LJWhiteSL_
Posted 02 April 2007 - 10:13 AM
Unless you can get some mega thin ones, you won't fit anything behind (specially with your big thick belt and pulleys).
Steve
Edited by 73LJWhiteSL, 02 April 2007 - 10:15 AM.
Posted 02 April 2007 - 11:08 AM
#6 _uglybob_
Posted 02 April 2007 - 06:27 PM
o well.
#7 _ChevLX_77_
Posted 02 April 2007 - 07:12 PM
#8 _uglybob_
Posted 02 April 2007 - 07:25 PM
#9 _ChevLX_77_
Posted 02 April 2007 - 07:44 PM
#10 _uglybob_
Posted 02 April 2007 - 08:10 PM
#11 _ChevLX_77_
Posted 02 April 2007 - 08:38 PM
#12 _MediuM16A2_
Posted 02 April 2007 - 10:34 PM
good boi.Mate i dont have any pics at the moment but i will take some tommorow.
#13 _why-psi_
Posted 02 April 2007 - 10:59 PM
Posted 02 April 2007 - 11:23 PM
#15 _why-psi_
Posted 03 April 2007 - 12:11 AM
#16 _v8slrtorana_
Posted 03 April 2007 - 12:28 AM
Burnout comp at Powercrusie this weekend will be the big test. Im in Darwin.
#17 _73LJWhiteSL_
Posted 03 April 2007 - 11:17 AM
why-psi if you are going to run the 5 core radiator, maybe you should try and get a smaller water pump pulley and see if you can increase the coolant flow a little? You might find your car runs a little cooler.
Steve
#18 _why-psi_
Posted 03 April 2007 - 04:47 PM
Posted 03 April 2007 - 06:18 PM
CHEERS Chris
#20 _73LJWhiteSL_
Posted 03 April 2007 - 06:27 PM
The reason I am not keen to replace my 2 core with a 3 core is if i do that i think my coolant flow rate will drop and the air flow through the radiator will be reduced (due to the extra row of tubes), possibly resulting in either a very minimal increase in cooling, no change or a reduction in cooling (read car overheats worse).
Steve
#21 _uglybob_
Posted 03 April 2007 - 07:04 PM
#22
Posted 03 April 2007 - 07:20 PM
I would expect that the more cores/tubes a radiator has the less restrictive it would be to water flow.cool thanks steve, i read about this somewhere also. was going to use an electric motor to run the pump like the moroso electric waterpump drive kit, but if i turn the pump faster it could cause cavitation, so i might try the biggest davies craig electric waterpumps and get rid of my mechanical pump
I think you will find the problem is that electric fans do not have the power to provide sufficient air flow through a five core radiator. Typically vehicles fitted with five core radiators have large engine driven fans that take a couple of HP to turn.
If you can find a vehicle that has a factory fitted five core radiator and electric fans then it would prove the theory wrong.
#23 _1uzbt1_
Posted 04 April 2007 - 10:07 AM
#24 _73LJWhiteSL_
Posted 04 April 2007 - 12:34 PM
My point was not that the 5 core would be more restricted for coolant flow, but that with 5 cores and much more tubes to flow through the coolant would move much slower through the radiator, simply because of the increased size.I would expect that the more cores/tubes a radiator has the less restrictive it would be to water flow.cool thanks steve, i read about this somewhere also. was going to use an electric motor to run the pump like the moroso electric waterpump drive kit, but if i turn the pump faster it could cause cavitation, so i might try the biggest davies craig electric waterpumps and get rid of my mechanical pump
Steve
#25
Posted 04 April 2007 - 07:08 PM
