black 202 efi
#1 _postal_dood_
Posted 14 January 2006 - 12:17 AM
well, what i found... when the engine waz recoe'd, (guy i bought it off said it waz reco's 40000k's ago) who eva did it waz blind!!! there is a bloody water jacket in the head that isnt in the block!!! nor the head gasket! , wtf is with that>???
but as for the block!!! im not going to say numbers but lets just say, the block #, and rego are diferent!!! not sure what the deal is there but somewhere along the lines they have been changed...
the pistons are 30thou ova size and i would say the rest of the bottom end would have had something strong in there aswell..
Posted 14 January 2006 - 09:10 AM
If it is a red block it may play into your hands a bit in that if it is a pre adr 27A block you "might" not have to fit all the emissions gear..but I am not the person certifying it.
#3 _CHOPPER_
Posted 14 January 2006 - 10:02 AM
#4 _postal_dood_
Posted 14 January 2006 - 11:05 AM
and the engine number starts with VL. which of course got me thinking its a vl carby block... but them im told that VL's didnt come out with 202, carby's/...
oh and the block is all black... not red, does this say anything?
oh and i cant tell u if its fully counter weight yet... when the head came off thats where i stopped.
Edited by postal_dood, 14 January 2006 - 11:05 AM.
#5 _postal_dood_
Posted 14 January 2006 - 11:10 AM
#6 _[BOTTLEDUP]_
Posted 14 January 2006 - 11:23 AM
I'd say red block... And for a 40,000km "reco'd" its got some rather nasty marks in the bores...
#7 _postal_dood_
Posted 14 January 2006 - 11:31 AM
#8 _[BOTTLEDUP]_
Posted 14 January 2006 - 11:36 AM
Grab a VK out of the classifieds for $200 rip the engine and take the bottom end. Flog the remains of the wreck off to recoup your cash and start afresh.
Posted 14 January 2006 - 01:19 PM
VL in the engine number doesn't have anything to do with VL commodores...It is a VK block
yes lat red 202 had 3.3 cast in the side.
#10 _postal_dood_
Posted 14 January 2006 - 02:09 PM
and what i was worried about is why or what to do with the hole in the head...
its obvious water has been hitting the gasket, and leaking into the cylinder, thus causing the blow by making bubbles in the radiator. so i have to do something about it...
i waz told this by someone else so if it is completely wrong please say so...
#11 _CHOPPER_
Posted 14 January 2006 - 04:10 PM
Head gaskets also blow because people don't know how to install them properly.
Posted 14 January 2006 - 10:13 PM
that gasket might just have had it..check everything is flat...and chuck a new one on...since it looks like your dowels are gone be absolutely sure the gasket goes on the right way or you will block things off.I am confident a new gasket (correctly installed ) will get you out of trouble.
#13 _postal_dood_
Posted 14 January 2006 - 11:01 PM
#2 Blue/Black six has extra coolant passages to suit the extra passages in the Blue/Black head.
when i asked about 202 red VS 202 black u said ^^^that... so are these the only diferences..?? if so, im just gona get the extra passage drilled.
#14 _postal_dood_
Posted 14 January 2006 - 11:07 PM
not sure if i showed this 1... but here we can see the block is missing a passage... lol, im a tour guide.... hahahaha
Posted 14 January 2006 - 11:50 PM
#16 _postal_dood_
Posted 14 January 2006 - 11:56 PM
Posted 15 January 2006 - 07:32 AM
#18 _postal_dood_
Posted 15 January 2006 - 03:39 PM
Posted 15 January 2006 - 07:42 PM
#20 _postal_dood_
Posted 15 January 2006 - 09:27 PM
i think im just gona drill biger holes and be done with it...
its still a good buy for 400, with xtras,...
but thanx for all ur help guys...
#21 _Sammy_
Posted 16 January 2006 - 02:45 PM
no hole between 1 and 2 cylinders same as your motor.
and here we have a blue 202 head .... you'll notice it has the same hole as your head.
i can tell you from experience and over 180,000kms that this hole is normal and doesn't cause issues.
my guess is your head is warped or it wasn't torqued down tight enough etc ....
#22 _postal_dood_
Posted 16 January 2006 - 03:19 PM
well im going down to the engine reco place near by and getting my head and block, smoothed out... (or whateva u call it),,, but u hit the nail on the head with that 1 sammy...
my block is the same as that 1... its gota be a blue 202... dude i bought it off is gona get a slapin!
#23 _Sammy_
Posted 17 January 2006 - 12:30 PM
if its a blue motor and its registered in a VK theres not really a drama, personally i've heard blue motors are better than black motors, however the VK EFI heads are the better option for a stock head.
and if its going into another car thats older than a VK then you have no dramas if its blue or black, blue = less pollution rules to abide by.
just remembered about a stock VK EFI head i got cleaned up ....
which prooves atleast the heads blue or black efi are the same ....
Edited by Sammy, 17 January 2006 - 12:39 PM.
#24 _[BOTTLEDUP]_
Posted 17 January 2006 - 01:20 PM
That's how all engines should be when they are being assembled...bguck!!! thats all i can say... thats clean!
#25 _postal_dood_
Posted 17 January 2006 - 01:39 PM
i will be keeping as little stock as possible in my engine... its already got a few things done to tha block, which is why i wanted to keep it... if only to save me the trouble of fitting the pistons to another 1...blue and black motors are identical in these respects though so the only real way i guess to find out for sure if its a blue or black is to look up the engine number or something ....
does anyone know how much anti polution shit im gona need to get it registered?
and how much of a restriction does this crap make?
