Ls1
#1 _lj chev_
Posted 14 January 2006 - 01:08 PM
#2 _seperf_
Posted 14 January 2006 - 02:35 PM
#3 _seperf_
Posted 15 January 2006 - 02:24 PM
Posted 15 January 2006 - 03:25 PM
In an LX you have major issues with oil pan, extractors and firewall clearance.
I have pictures of the LJ for sale with an LS1 in it, even tighter then an LH-X, brake booster is moved and a remote unit needed, you need to run the fan on the front side of the radiator, custom pipes and oil pan modifications, but I dont think you will get a LC/J registered in NSW with anything larger then 312ci these days. LS1 is 346ci
Blocks are different to old SBC, larger in all area's.
A powerglide will bolt straight up but the converters are the MAJOR difference, you do NOT run a regular SBC converter on an LS1 with old trans, destined to be destroyed.
Good luck, just buy an engine and work around it, you'll get there.
Edited by LS1LX, 15 January 2006 - 03:26 PM.
Posted 15 January 2006 - 05:10 PM
is that one forsale in Melb for $20,000I have pictures of the LJ for sale with an LS1 in it
Posted 15 January 2006 - 06:56 PM
Sure was, if you want I can pass on the owners number and email address to youis that one forsale in Melb for $20,000
#7 _lj chev_
Posted 16 January 2006 - 06:19 PM
thanx ryan
#8 _Keithy's_UC_
Posted 17 January 2006 - 11:07 AM
Keith
Posted 17 January 2006 - 09:08 PM
Now there everywhere, I knocked back a complete front cut for $1,500, but I know the guy.
I wouldnt pay more then $3,000 for a complete engine, you can pick up an average mileage one for $2-2,500, try go for a VX on engine as they have the LS6 manifold standard, cheap and easy 10HP.
My engine was tuned and run on engine dyno at Sam's Performance.
Stock made 300HP (225kw at engine), tuned with extractors the engine made 372HP (this is what they make at engine when you see a tuned LS1 with 225 RW KW) then we slotted in a comp 220/220 camshaft (very small, idles at 700rpm) engine made 412HP/407Ft/lbs (560Nm), first tune it needs to go back when its running and adjust it a bit, should see near 420HP at engine. If I had a stock trans like the VT/X boys it would make around 265kw at wheels
Idles like stock, it is a puny camshaft, you wouldnt know its been changed from the lack of cam overlap.
I think 410+HP, 410Ft/Lbs, TH350 Full Manual 3,400 9 1/2" converter, 3.55:1 Detroit Locker, it should go alright on the street, should run a high 12. Weigh approx 1350KG. Plus its around 70kg lighter then regular SBC.
#10 _lj chev_
Posted 17 January 2006 - 10:03 PM
what mounts did you use in the lx? i should be getting a dummy block soon from work to play around with so i spose i should get some mounts soon.
thanx for your help
Posted 18 January 2006 - 07:12 AM
TH350's strong enough for 450HP, well the internals Ive built it with, PG's are good but its just 1 shift, had 1 in a street car and its a boring drive.
Turbos on LS1 in LJ street car, I think you need to get in contact with the lj ls1 guy, unless your LJ has another 2 ft of room each side? you would need to bring the turbos all the way forward in front of the engine, a lot of fabbing required.
Check ebay for engines there dirt cheap.
#12 _tj81_
Posted 22 January 2006 - 09:37 PM
Cheapest ive seen is around the $5800 mark from Ballarat Auto Wreckers. Theyve got some good stuff if anyone is over that way and in need of some good gear.
Posted 23 January 2006 - 06:01 PM
Off a mate.Wouldnt mind knowing where you could get a front cut for $1500, thats a sweet deal. could always use a spare engine !
It'll be my spare or for my next torana.
