Front wheel arches
9 replies to this topic
#1 _bones_
_bones_
Posted 06 April 2007 - 10:25 PM
I need some front wheel arches to replace in some flared front guards. Are 4 cyl and 6cyl the same?
Thanks in advance,
Bones
Edited by bones, 06 April 2007 - 10:26 PM.
#2 orangeLJ
  • 10,259 posts
Posted 07 April 2007 - 10:24 PM
in short... yes.
#3 rodomo
  • 17,999 posts
Posted 08 April 2007 - 12:12 AM
What model?
LH onwards yes but before LH I would say no as the guards were different for 4 cyl.
#4 orangeLJ
  • 10,259 posts
Posted 08 April 2007 - 05:18 PM
sorry i assumed he was talking bout LH forward, but LC LJ have shorter fronts then the 6 cylinders, BUT i would think the actual arch would be the same just not the whole gaurd.
#5 _bones_
_bones_
Posted 08 April 2007 - 09:33 PM
I realise that the guards are shorter overall for the 4 cyl, but I am only interested in the wheel arch section, about 50 to 100mm around the radius of the wheel opening.
I would have put my question in the LH/LX section if it was a LH/LX, but then again I wouldn't want to do a wheel arch replacement on a bolt on guard. Maybe I should have said LC/TA/LJ. There maybe a hint of sarcasm there, but it does seem very easy to be misunderstood in a forum.
Bones.
#6 Dr Terry
Dr Terry
  • 3,277 posts
Posted 09 April 2007 - 12:10 PM
Hi Bones.
I'm pretty sure the actual front arches themselves on 4 cyl HB/LC/LJ/TA Toranas are smaller than the LC/LJ 6.
Dr Terry.
#7 RIM-010
RIM-010
    DON'T PANIC
  • 8,076 posts
  • Name:Tim
  • Car:LJ 2 Door - HQ Premier
Posted 09 April 2007 - 02:08 PM
Kaz has a 4cyl LC, ask her...
Tim
#8 _jap-xu1_
_jap-xu1_
Posted 09 April 2007 - 02:44 PM
im picking up a 4 cyl lc next week to chop up.
i will suss it out for you
if you need the guards ill have them
#9 _jap-xu1_
_jap-xu1_
Posted 09 April 2007 - 02:53 PM
looking at this id say no
#10 _gtr161s_
_gtr161s_
Posted 10 April 2007 - 05:39 PM
you could be right there jap-xu1.
personally i wouldnt do a guard arch.
the area is very big which needs fully welding, which in turn will shrink the panel dramatically even if you try cooling it as you go.
go for unpicking the guards, its well worth the effort
i unpicked both guards plus front apron in one piece, they virtually slip straight off the donor and onto your car.
https://cache.gmh-to...lyredgtr04a.jpg
before
https://cache.gmh-to...sidefrntend.jpg
donor
https://cache.gmh-to...frontendoff.jpg
donor
https://cache.gmh-to...me/PC040299.jpg
after
