help me get spark!
#1 _jap-xu1_
Posted 09 April 2007 - 01:27 AM
ive been wiring my msd and its not sparking
the msd unit has switched 12v and main power
as it was it had wires running to each side of the coil and then from there they ran to the electronic dizzy.
now i run the violet and green wires from the msd direct to the dizzy wires
the orange and black from the msd to the coil
as far as i can tell thats righ but i have sweet fa spark lol.
someone set me straight
cheers leigh
Posted 09 April 2007 - 01:46 AM
Adam
#3 _jap-xu1_
Posted 09 April 2007 - 01:48 AM
the msd unit is a marine version of the 6a but its all the same wiring, its just a waterproof unit.
Posted 09 April 2007 - 02:03 AM
Adam
#5 _jap-xu1_
Posted 09 April 2007 - 02:09 AM
Posted 09 April 2007 - 02:53 AM
Posted 09 April 2007 - 08:44 AM
i would look at bypassing the resistor wire if you are
dave
#8 _jap-xu1_
Posted 09 April 2007 - 10:29 AM
im just not getting a trigger signal from the dizzy.
ive tried switching the wires at the dizzy and still no go
#9 _jap-xu1_
Posted 09 April 2007 - 10:49 AM
this happens when the connection between the 2 trigger wires is broken.
i just tested the wires coming out of the dizzy and they do not flow current at all so there is no way they can break the current if they wont flow it in the first place.
im confused at how to trigger this msd
#10 _T0rana_
Posted 09 April 2007 - 10:52 AM
#11 _jap-xu1_
Posted 09 April 2007 - 10:55 AM
#12 _Bomber Watson_
Posted 09 April 2007 - 12:30 PM
also, if you havnt already, rip the moduel off the side of it, just bypass it. msd dosent need it.
#13 _jap-xu1_
Posted 09 April 2007 - 01:07 PM
i then bypassed the module using the msd and still no go lol.
at this rate i will be bald within the hour lol
#14 _bodallafella_
Posted 09 April 2007 - 02:31 PM
If you connected the module (the wires that used to go to the coil) to the violet & green wires there is a good chance you have blown the MSD. To check if the MSD still works, bridge the voilet & green wires and it should fire.
#15 _jap-xu1_
Posted 09 April 2007 - 02:39 PM
#16 _jap-xu1_
Posted 09 April 2007 - 02:41 PM
it has 2 wires,one green and one light brown.
if i was to use the points style trigger where would i run the white wire to ?
#17 _bodallafella_
Posted 09 April 2007 - 03:05 PM
If it fires when you manually trigger it while it is wired to the car then your problem must be the signal from the distributor. The only wires connected to the dizzy should be the violet & green wires connected directly to the magnetic pickup. Check the connections with a multimeter, if they are OK then the pickup in the dizzy is probably stuffed. Check it with the multimeter, if it is an open circuit it is rooted.
Edited by bodallafella, 09 April 2007 - 03:08 PM.
#18 _v8slrtorana_
Posted 09 April 2007 - 03:21 PM
Posted 09 April 2007 - 04:34 PM
Adam
