original radio
#1 _cameron1_
Posted 12 April 2007 - 04:30 AM
thank you
#2 _Flamenco_
Posted 12 April 2007 - 04:39 AM
http://www.gmh-toran...pic=12133&st=30
Edited by Flamenco, 12 April 2007 - 04:39 AM.
#3 _cameron1_
Posted 12 April 2007 - 04:53 AM
#4 _Flamenco_
Posted 12 April 2007 - 05:07 AM
Posted 12 April 2007 - 08:15 AM
#6 _devilsadvocate_
Posted 12 April 2007 - 09:54 AM
Best I describe it: it is AM only, has five push buttons below an am band cut into an aperture on the dash, and has two knobs either side, one with a pic of a quaver(music note) on it(most likely worn off by now) It is installed on the very top row of the centre console
The one that knoath has a pic of, is not the one supplied for a SL torana, it is the am/radiocassette unit that was supplied standard on the sl deluxe model or perhaps as an option and was installed in the console below the heater outlets. When this option was selected the top row of the centre console was left with the cut out.
I do have one of the original sl radios at another location,but wont be going there for a few days to take a pic.
#7 _Big T_
Posted 12 April 2007 - 12:47 PM
#8 _devilsadvocate_
Posted 12 April 2007 - 08:33 PM
Edited by devilsadvocate, 12 April 2007 - 08:37 PM.
Posted 12 April 2007 - 09:04 PM
Devil's Advocate is correct. It was installed in the lower front console, in front of the gear shift, below the heater vents.
My UC is a SL Deluxe. So this may have been the optioned up version (note the built in cassette player)
Hope this helps one way or another.
#10 _Big T_
Posted 13 April 2007 - 05:15 PM
Model UC8UG69
Body 630457M
Trim 1926-63V
Paint 568-30517
Eng L20 Trans M40 Rear Axle GU4
May help with the mystery ICE !!
Cheers,
T
#11 _cameron1_
Posted 13 April 2007 - 06:03 PM
just wondering if the Original SL UC torana radio that u have at the other location if u would be intreasted in selling it (if its in good cond)
#12 _devilsadvocate_
Posted 13 April 2007 - 07:48 PM
uc8uG69 says its an S model Torana, gu4 says its a 3.08 diff and L20 is a 6cyl, m40 trimatic. Though guessing L20 is a 202 since it has the 3.08diff.Off Topic but sort of relevant.....Im not really sure what my UC is/was ?? Can someone decipher the following codes please?
Model UC8UG69
Body 630457M
Trim 1926-63V
Paint 568-30517
Cheers,
T
So the radio was most likely fitted after the factory. Dont know about the sunbird ashtray......
Will chase up that original radio, hopefully it is still in the rafters of the garage where I put it 15 years ago!
#13 _JamesB_
Posted 13 April 2007 - 09:32 PM
Yep, that's the one that came in my UC SL Hatchback. It was part of the $390 "Deluxe Option Pack".Here's the radio out of my UC.
#14 _azzapove_
Posted 17 April 2007 - 11:46 PM
