Hi
This might be a silly question, but what is bump steer.
I have just brought an lh slr. I have converted the front stubs to hq and am running the lh steering arm. I am also useing pbr alloy calipers. I haven't driven the car yet as it is not registed. I am going to use the car on the street, tarmac rallies and sprint sessions on track days. I hopeing to fix any geometry problems before i register it. Any help would be much appreciated.
Bumpsteer
boblhslr
, Apr 12 2007 08:30 AM
5 replies to this topic
Posted 12 April 2007 - 08:30 AM
Posted 12 April 2007 - 08:59 AM
It is to do with when you hit bumps the car steers in the direction of the bump. Usually caused by incorrect toe-in in my experience.
Have a look here:
http://www.bakerprec.../longacr17a.htm
Have a look here:
Posted 12 April 2007 - 09:11 AM
Can also be caused by dubious front end conversions where the the tie rod arms are not parallel to the ground. When a front wheel hits a bump the arc travelled by the tie rod arm causes the wheel to 'self' steer.
Posted 12 April 2007 - 09:14 AM
Thanks Rodomo. That certainly answered my question
What is the easiest way to fix the problem. Would it be better if i was useing a UC steering arm.
Posted 12 April 2007 - 09:44 AM
Ideally A9X or L34 steering arms, not sure on the UC ones. I think Harrop make a A9x repro steering arm.
Posted 12 April 2007 - 06:25 PM
The Harrop A9X repro arms are your friends if you have HQ stubs.
UC ones are better than LX but not as good as the A9X ones.
M@
M@
