Just when I thought I had it worked out.
eg. An 8" rim with 4" backspace would have a 0mm offset right?
A company in the USA has 8" rims 4.5" Backspace but measuring 0mm offset, does this mean they are measuring the lip to gain the extra 1/2".
As if I send thru my measurements under my means of measuring I have a feeling my rims will be come over and be 1/2" closer to the guard and they will protrude.
Another offset measuring question, is USA differen
LS1LX
, Jan 15 2006 10:36 AM
2 replies to this topic
Posted 15 January 2006 - 10:36 AM
Posted 15 January 2006 - 10:56 AM
I found this website, is this how wheels are measured for offset in Australia as well?
http://www.rsracing....tech-wheel.html
#3 _CHOPPER_
Posted 16 January 2006 - 07:05 PM
#1 That's what I would have thought.#1 An 8" rim with 4" backspace would have a 0mm offset right?
#2 A company in the USA has 8" rims 4.5" Backspace but measuring 0mm offset, does this mean they are measuring the lip to gain the extra 1/2".
#2 This appears to be the case.
The obvious problem that arises with the Yankee backspace system, is it doesn't take into account rims that have different thickness in the bead. This then makes it hard to compare apples with apples.
