MSD Ignitions
#1 _jabba_
Posted 12 April 2007 - 10:20 PM
http://cgi.ebay.com....1QQcmdZViewItem
Would anyone recommend this setup, i would be willing to spend UP TO $500.
Damien
Posted 12 April 2007 - 10:22 PM
#3 _Monkey_
Posted 12 April 2007 - 10:41 PM
#4 _jap-xu1_
Posted 12 April 2007 - 10:42 PM
it looks like a cheap chinese ripoff
#5 _jabba_
Posted 12 April 2007 - 10:46 PM
Could someone recommend a budget ignition setup?
Damien
#6 _MYLJ_
Posted 12 April 2007 - 10:59 PM
I wouldn't recommend this set up .
If your looking for a reliable electronic dissy for a mild engine that's not going to get revved 6000rpm then I'd recommend a factory hei dissy, they come with the coil in the cap and require only one posative wire attached to hook them up (plus another wire for a tacho if your running one )
very simple and very reliable set up, I've used heaps of them, they are cheap too, about $100 to $150 for a complete secondhand dissy with the cap.
only issue may be space in the engine bay up against the fire wall if its in a torana, if its in a HQ then there's no problem with room
#7 _jabba_
Posted 12 April 2007 - 11:36 PM
There were other "HEI" dissys on there for <$100 new, some labled 'Procomp' others just 'HEI' but looked almost exactly the same!
<edit> HQ, lots of room .
<edit2> or this seems to be the same as above but cheaper ?!?
Edited by jabba, 12 April 2007 - 11:42 PM.
#8 _MYLJ_
Posted 12 April 2007 - 11:48 PM
yes thats the type I mean, I'm not sure how good either of those 2 you've found on ebay are, if they are what they claim to be then then I can't see a problem.So just to clear things up, we are talking about this item.
I usually just get a secondhand one from one of the American importers
#9 _jabba_
Posted 13 April 2007 - 08:24 AM
I guess i can only try them and find out.
#10 _SLR Goat_
Posted 08 May 2007 - 07:48 PM
#11 _rorym_
Posted 08 May 2007 - 08:02 PM
#12 _Bomber Watson_
Posted 08 May 2007 - 08:58 PM
basicaly, only run brand name gear if you wanna get serious. persoaly i only use msd gear, but craine fireball stuff is supposed to be ok
msd gear may be expensive, but you will only buy it once.
#13 _HatchmanSS76_
Posted 08 May 2007 - 09:49 PM
As MYLJ suggests std Hei is good or even the crane gear is good also.
#14 _SLR Goat_
Posted 08 May 2007 - 10:28 PM
Lol tell me about i took a hit from one of their dizzys a while back not cool at allProCRAP ignition systems/components should not be touched unless you wear heat proof gloves because you'll get burnt.
Posted 13 May 2007 - 01:14 AM
Thanks,
Dave
#16 _dave720gtr_
Posted 13 May 2007 - 11:57 AM
Lol tell me about i took a hit from one of their dizzys a while back not cool at all [/quote]
Lol" i once got belted by a MSD6a +blaster 2 coil working on a mates furd f100
bad lead bit me big time lol" 45000volts or more .hit my head on the bonnet?
then it got my mate too hehe"
